Old 12-18-2022, 09:31 PM
jfaison jfaison is offline
Default Mower Deck Rebuild For 782 IH CC
Hello,
I have a 38 inch mower deck that came with the 782, I am rebuilding. The deck is the original and in fair to good shape. I have taken it apart. I am getting ready to have it powder coated. I have taken the most of the deck apart, I spend the money to powder coat it white, I have a few questions:
1. I need to replace all of the pulleys for the deck. Are the pulleys available?
2. I also need to replace the tension spring (belt tension spring). Is the spring available?
3. What is the best method a rusted nut on the tensioner arm. It is rusted pretty badly. It looks like there is more hardware on the bolt
than just a nut. this is the bolt that the spring on the tension arm.
4. The Phillips head bolts in the deck are rusted badly. The heads seem to strip easily. How should I remove them? The powder coater
said I could leave them and they will protect the threads when powder coating.
Thank you.
Old 12-19-2022, 08:00 AM
Yes, 956-3006 (outer pulley) and 956-3007 center pulley
Yes, 932-3009 Torsion spring
What is the best method a rusted nut on the tensioner arm. It is rusted pretty badly. It looks like there is more hardware on the bolt than just a nut. this is the bolt that the spring on the tension arm.
I assume you are talking about "nut removal". With that in mind (a) heat, (b) impact driver, or (c) cut off grinder
Don't know where there are Phillips Screws. General speaking, you can take a cut off wheel on a Dremel type of tool, and grind a slot into the head, then take an appropriate slotted screw driver and see if you can turn them out. Also see suggestion #3.
Old 12-19-2022, 11:36 PM
Thank you very much. There are 6 Phillips head bolts on the deck that attach the side pulley guards to the deck. They are rusted pretty badly. Here are two pictures. Do you think I could tap them out? I have tried Kroil.
Thank you very much. I learn a lot from this forum.
Old 12-20-2022, 07:20 AM
I don't know if you have access to a Welding Torch, but I would heat the head of the Phillips screws red hot. Once the cooled down, then try to remove them.
Old 12-22-2022, 10:34 PM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
You could also try a manual impact driver.
https://www.amazon.com/DURATECH-Reve...%2C111&sr=8-55
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 12-23-2022, 10:43 AM
By the looks of that deck shell, if you sand blast it, you will be able to see through it.
Why do you want to take those out?
Looks like the nuts came off w/no issues.
Are some of them rusted clean off?
Knock 'em out with a hammer and replace them.
They are not original, the originals were just 5/16" bolts that were spot welded in place.
Old 12-25-2022, 08:16 PM
Thank you for the help.
If the mower deck survives the cleaning and powder coating process, I plan to rebuild it. I am using Powder Keg in Gluckstadt, Mississippi to clean and powder coat. All they do is powder coat. I hope it will be in good enough shape to rebuild.
Also, where would be the best place for purchasing parts? It looks like I am going to need a new idler arm assembly for a IH 38 inch mower deck that came with a 782. The deck's serial number is U320016U116719.
Thank you again for all of the advice.
Old 12-25-2022, 09:13 PM
Farmall450's Avatar
If it doesn't survive that's a good opportunity to put the proper 44/50" deck or even a 46" GT.
Old 12-28-2022, 09:02 PM
Thank you. Here are pictures of the idler arm. How can I rebuild or should it be replaced? Any help is appreciated.
Old 01-02-2023, 01:13 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
MTD/Cub Cadet still sells an updated re-engineered part 759-04324B or 703-0118. What was re-engineered is that large pivot bolt is now greaseable in an effort to keep it from seizing up and wearing out.
Now, just the updated pivot bolt is available separately. Part number 738-3005 or 638-04012A.
