Old 11-08-2022, 07:53 AM
BKsCC BKsCC is offline
Default Cub Cadet 982
There's a 982 for sale near me that I'm very tempted to go snag. Pics below; looks in solid shape. Also comes with weights, 50in mower deck, and snow blower. Runs and drives. Guy's asking $1,600.
Don't know it if has the Class-0 3-pt and PTO though. Was that standard, or was that an option? If it was an option, can that be added later?
From my research, some other questions:
1. I understand the Onan engines are hard to repair due to the difficulty of finding parts. Are there any reliable sources for them, or how have current owners here done it?
2. I'd be interested in brush hogging with it if it has the PTO. So far the only brush hog I could research for it was the Woods M4-2 Billy Goat, which they stopped making decades ago...so practically unobtanium because of the 2000rpm requirement...are there any others?
3. Are non-engine parts and components mostly interchangeable among the red 482, 582, 682, 782 series?
4. If I have older Cub Cadet implements like a 1A tiller are there adapters to make them work with the 3-pt hitch? I suspect the belt drive and gear box running gear required probably won't mount in the presence of the PTO but then again I've little experience with these.
Thanks all!
Old 11-08-2022, 09:37 AM
Optional, and yes they can be added.
Haven't heard of the difficulty issue, but more so the price of Onan parts.
Some yes, and some no.
The IH built Tillers would NOT fit on any Cub Cadet Super.
Old 11-08-2022, 09:53 AM
Cool, thanks!
I'm betting if it doesn't have them then finding them aftermarket is basically predicated on finding another 982 that has them. If that's what I really want then that's probably what I should wait for, eh?
Was it a completely new implement line for the Supers that was incompatible with older stuff? Are mower decks and snow blowers still adaptable? Cause I see it uses the same mule drive.
Old 11-08-2022, 11:04 AM
The Supers, were basically a "CAT 0" implement Tractor. Since the frame is longer than a standard Garden Tractor, the mule drives were longer also. Some implements from the Garden Tractor type would transfer over, but mostly implements specifically for SGT should be sought out and used.
Old 11-08-2022, 12:51 PM
farmer52 farmer52 is offline
I am beginning to like the 82 series tractors. Were these the last "true" IH built models?
Ken
Old fart - new to Cub Cadets
Looking for a nice original low hour 1772 or 1782
Old 11-08-2022, 12:56 PM
It was an IH design. They produced them until the sale to CCC/MTD in 1980. CCC continued the 82 series until 1984.
Old 11-08-2022, 03:11 PM
Were the CCC machines identical? Did CCC use the same model numbers? If so, how can one tell the difference? Thanks!
Ken
Old 11-08-2022, 04:30 PM
Yes, and Yes.
The Factory Code, and all IH serial numbers were <699,999.
Old 11-22-2022, 02:00 PM
So after many exchanges about when to meet up, finally got out to see the thing.
He'd spent $800 to have the front main seal and other gaskets and such replaced, fresh oil and filters, only to have the hydro relief valves leak on him.
Like, it was literally squirting Hy-tran up and out of the holes in the top of the relief valves. At an alarming rate.
This after he claimed to have had them go through the seals on the back end too. What in the hell did that dealership do to make that happen? I'm sure it's just a matter of replacing the valves, but what causes that? Over-filled the hydraulic system? The receipt he showed me confirms he paid for them to mess this thing up.
And the hydro linkages aren't adjusted correctly. Stomp on the brake in reverse and it'll keep going after you let your foot off the brake while in the neutral position.
Engine runs great though and everything else appears in order. 444 hours on the original Onan engine. His father in law bought it new in 1980. Model 450 snowblower and an original, if in very rough shape, IH snow cab.
Old 11-22-2022, 02:10 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Exclamation
Those relief valves are ticking time bombs. They go without warning, and spew Hytran out of them. Not a huge deal. They are easy to find, and easy to replace.
