Old 06-18-2022, 06:48 PM
Barcode Barcode is offline
Default Cub 124
OK, odd issue I'm having today. When I go to start it, it will just turn over but if I pull plug wire off and jump spark it, will run but if I hook it up it kills it.
Old 06-18-2022, 08:50 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Examine spark wire and spark plug and replace if necessary. My guess is something's grounding the spark.
Plow blade
#2 Cart
QA36 snowthower
Old 06-19-2022, 11:54 AM
Wire and plugs are fine just don't understand how it will work if I jump spark on plug or coil it will start
Old 06-19-2022, 12:24 PM
Check points, when it is running does it throttle up?
Old 06-19-2022, 03:45 PM
If iam able to hold wire above coil to keep it running I can throttle up but now I think I lost spark altogether now
Old 06-19-2022, 03:54 PM
I'm going to start with changing out coil
Old 06-20-2022, 08:15 AM
Billy-O's Avatar
Ignition coil testing info: https://www.onlycubcadets.net/forum/...highlight=coil
Like Lew says, I would inspect the points AND condenser, too!
Plow blade
#2 Cart
QA36 snowthower
Old 06-20-2022, 06:51 PM
Default Points
I think points are working opening and closing with spark
Old 06-23-2022, 06:46 PM
Ok so pulled plug got good spark but still will not start
Old 06-23-2022, 07:21 PM
Billy-O's Avatar
OP has sent me a PM indicating he has replaced everything and has good spark but no start. So I'm bringing this back to forum for all to see and share their thoughts. Assuming fuel and compression is good, I think maybe timing is suspected:
Using timing light:
https://www.onlycubcadets.net/forum/showthread.php?t=14
Using a multimeter:
https://www.onlycubcadets.net/forum/...ead.php?t=4405
Plow blade
#2 Cart
QA36 snowthower
