#21
Sorry I called shade equipment our local cub cadet dealer.
#22
#23
![]() Quote:
#24
![]() Quote:
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
#25
Sorry, I missed the link. Being 72 and from VA makes me a little slow.
#26
![]() Quote:
#27
Do I need to remove the manifold pipe that is above my fuel pump to replace it. 2072 sgt
#28
![]() Quote:
#29
![]() Quote:
I'll stick with OE recommended parts and fluids. Seems like too many cheap f**ks in this hobby, and then they wonder why stuff doesn't hold up or work well. Rarely can have it both ways. So you put diesel engine oil in your hydro? This is what this thread is about.. ![]()
![]() 582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
#30
![]() ![]() Now I'm really confused! I can't find in the manual where it says to use IH Hytran anywhere. Should I run Hytran in my JD 430 too? Those Deere guys will be pissed if they gotta go to an IH dealer to get fluid for their hydro's. What does IH say about using type F automatic transmission fluid? The maker of the hydro says it's okay to use. Oh, maybe IH, Deere, Steiner & Wheel Donkey want you to buy their overpriced oil for profit. ![]() Here be the manual for the pump. https://media.toro.com/servicemanuals/sd_15svc.pdf
