Old 12-22-2010, 03:43 PM
Larry64's Avatar
Larry64 Larry64 is offline
Default Weight
How much weight are you running on you GT with a snow blower on it? I have chains and a QA42 and about 60lbs on the rear. I still have traction problems.
1975 Cub 1650, JD LT155
Old 12-22-2010, 04:01 PM
gcbailey's Avatar
gcbailey gcbailey is offline
I don't think 60lbs is nearly enough... For my snow blade I'm running about 350lbs of weight then myself...
Gary
Old 12-22-2010, 04:40 PM
CCdude's Avatar
CCdude CCdude is offline
Last winter I had 150lbs on my 106 in addition to my 160 and chains and it had enough traction to push my Qa36a through 2ft of snow. With a 42 inch thrower you will probably want to add more than that seeing as the 42 inch thrower is going to be heavier than the 36.
Old 12-22-2010, 05:13 PM
JayBrd's Avatar
JayBrd JayBrd is offline
I am running 9 gallons (each) of windshield washer fluid in 26x12x12 tru-powers, which put's them at roughly 100lbs'ish each, no chains. I have no traction issues when I drive it right..
60lbs total weight is a bit too light, adding washer fluid is cheap and easy. Just remove rears, and lay them on thier side. Let all the air out, PARTIALLY break the bead on the up side and pour in. Re-set the bead and fill to pressure..
Jay N.
Eau Claire, WI
RED 82 Series...
Iowa Farmboy Iowa Farmboy is offline
28 gallons of fluid all together at 7.6 LBS per gallon.
The cub plastic rear weights at 80lbs each
6 40 lbs suitcase weights on the cat o
my self at 350 lbs
and 2 link chains
all on a 2072 with a 45" two stage blower
I figure it at some were in the 2000lbs all together
over kill but have never been stuck moving snow
Josh
1989 SGT 2072 (restored)
60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake
Cub 128 with creeper and rear PTO with reverser(next project)
IH built 682 and 782 that will combine to make one
Old 12-22-2010, 08:09 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
I have 2 wheel weights at #75s a piece = #150 . Plus i hang 2- #50 suitcase weights on the back of the sleeve hitch all on a 782 w 42' Haban snow thrower chains n ag tires on the back. Here are some pics not the best but its's what i had on file.
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 12-22-2010, 09:51 PM
Merk Merk is offline
This is the set up I use to blow/throw snow:
There is no extra weight in or on the tires. Tractor has 10.50 turf tires and 2 link chains. Tractor has a manual trans (only 500 to 600 units made). Snow thrower is 44 inches wide. Tractor was new in 1996.
My blade tractor:
Rear tires are 23-8.50-12 ags that are loaded with fluid. Wheel weights are from a green tractor. Paid $35 for the set.
Once in awhile I have a traction problem.....usually on ice.
Old 12-23-2010, 02:11 AM
johncub7172's Avatar
as for my drive, i dont care if you have ag's or not....if you cant bite the ice you are going no-where.
Old 12-23-2010, 02:30 PM
MrGitrdone41's Avatar
On my 1812 I have 4 link chains and 80pounds of weight in the rear that are blocks. It goes great and i have the tires at 10 pounds in each tire. It is now pushing snow.
Old 12-28-2010, 04:28 AM
cdlong's Avatar
cdlong cdlong is offline
We got 4 inches offically, but had some 1 and 2 ft drifts. I had the 1450 and 54" blade with 70# weights per wheel and my 214 lbs + 4 link V bar chains. I spun a lot trying to go up the neighbor's driveway with the blade down. Seams I spun a lot in reverse. I'm going to change to the 42" blade for the next one if I can't use the QA36A.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
