Old 02-15-2022, 12:12 PM
EternalArianne EternalArianne is offline
Have you tried yer local Walmart?
Yeah Walmart did have 20W50 synthetic but it was also listed as motorcycle oil. It was around $9/quart.
Old 02-15-2022, 11:38 PM
Farmall450's Avatar
Most list it as that. My dad ran into the same thing for his Z Force ZTR (also hydro gear transmissions).
Old 02-28-2022, 09:18 PM
Ok I drained the fluid and installed a new OEM filter, then filled it with 6 quarts of 20W 50 oil. Checked the dipstick and it showed FULL. Drove it around and it seemed fine. No drips, no leaks.
Let it sit for 2 days and now dipstick shows ADD. I noticed it was not entirely level, so I disengaged the Hydro and pushed it forward a bit until it's level. Now dipstick reads HALF FULL.
I don't see ANY fluid on the ground, where did it go? I don't see anything around the drain plug or filter itself, no way it lost 3 quarts (half) just sitting 2 days...
Old 03-01-2022, 12:38 AM
Billy-O's Avatar
Billy-O Billy-O is online now
You have a dipstick that reads HALF FULL? Picture please! Most dipsticks I've seen shows the lowest allowable level as well as the highest allowable oil level. I've never seen a HALF FULL! A manual I found online advise that your 2155 takes
approximate 6 quarts. Did you check your oil after running it the first time. I'm sure some oil level loss would be attributed to displacement into oil filter as well as splashed onto gears before settling down. .....So, I'm curious to how much more oil you will need to top off the dipstick. I bet it's less than a quart.
Plow blade
#2 Cart
QA36 snowthower
Old 03-01-2022, 08:06 AM
By half full I mean between the ADD and FULL marks. It showed FULL after I drove it around post fluid change.
Old 03-01-2022, 09:04 AM
Billy-O's Avatar
A reading between add and full means the oil is in acceptable range. So you are good!
Plow blade
#2 Cart
QA36 snowthower
Old 03-01-2022, 09:08 AM
Ok whew I was beginning to wonder if it all evaporated lol
Old 03-01-2022, 11:32 AM
Here is how to check your fluid per page #23 of the Owners Manual.
Here is the correct and proper Hydro fluid to use, per the Owner's Manual, on page #60. 737-3055, This part is replaced by 490-000-C051.
Old 03-15-2022, 09:31 AM
MBY852's Avatar
MBY852 MBY852 is offline
Originally Posted by ironman View Post
If you take time to do a Google search on the subject of your anxiety, you will find that the overwhelming consensus of results says that adding synthetic lubricants to conventional lubricants, or vice-versa, has no ill affect.
The only drawback is that if the synthetic is not 100%, you do not get the 100% of the benefits of synthetics.
Has anyone used Traveller universal Tractor Trans/Hydraulic Fluid instead of CC 737-3025?
CC Model: 127 w/42" deck
CC/MTD Model: 2155 w/42" deck
.....DAD bought em new.....
Old 03-15-2022, 11:25 PM
Ozcub's Avatar
Ozcub Ozcub is offline
A little bit of information
Oz
