Old 02-15-2022, 10:52 PM
Farmall450's Avatar
Default Plastic Coming off Wheel Weights
Any good fix for this besides trimming what is left down flat?
Will the concrete actually hold up w/out plastic?
Old 02-15-2022, 11:52 PM
Ozcub's Avatar
Ozcub Ozcub is offline
Flex seal or rubberised undercoat or plasti-dip may solve your problem
https://www.homedepot.com/b/Paint-In...vZc8kfZ1z1a3k3
Oz
Old 02-19-2022, 06:49 PM
Getter-Done's Avatar
Getter-Done Getter-Done is offline
I have some I need to fix.
I would use a fiberglass repair kit.
Make wooden dowels to cover up the bolt holes, that can be removed after the fiberglass cures.
Turn it face up and lay the fiberglass over the whole thing.
It may take 2 or 3 applications .
Once done with that,
Coat it with Flex seal to make it look a little bit Prettier
Old 02-19-2022, 08:47 PM
Farmall450's Avatar
Oz
Not bad ideas -- I wonder if I can just trim a nice band where the radius/wear is and call it a day. The concrete shouldn't mind
Old 02-20-2022, 07:43 AM
I think the concrete will crumble, deteriorate and fall out if left expose to elements, gravity, rotating force & bumps and bruises.
That is one of the reasons my set is still sitting on the shed floor.
Old 02-20-2022, 08:44 AM
Farmall450's Avatar
Clearly the plastic wasn't able to protect it from those either
Fair points though. I don't plan on hitting anything, but maybe a little plastidip or flex seal will help it out.
Old 03-01-2022, 07:50 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Maybe the stuff they use for pick up truck bed liner!?!
Plow blade
#2 Cart
QA36 snowthower
Old 03-01-2022, 09:17 PM
Farmall450's Avatar
I have a half can of plasti dip somewhere that I think is going to get the job. I know that should stick. Good call on bedliner too.
Old 03-01-2022, 10:05 PM
What have you been running over to wreck them like that??
Old 03-01-2022, 10:06 PM
Farmall450's Avatar
Bought it that way.
