Ok I have about had it with this one. My cub sits outside and the choke and throttle cables are again stuck. Throttle cable broke off up at the lever.
Are there stainless cables I can attach to the CC throttle lever, or can these be covered in heat shrink or other tubing to keep the lube inside and the water outside? Ideas welcome!
Model 100 Dec 2020 - Running condition, has snow plow! Model 123 Nov 2020 Hydro needs much work, or resto, building front end loader for this one Model 100 Feb 2019 apart for total frame-off / sandblast etc resto Model 70 Sep 2020 needs total resto and an engine, or for parts Model 70/100 Mar 2021 buried in rust, frozen engine, got free for parts. two spare hydro rears "in for a penny, in for a pound!" |
Try searching push and pull cables in the marine industry....for boats. They do make stainless.
This is an example but I don't know if this fits: https://www.napaonline.com/en/p/BK_7...ng_dcoe_google Otherwise I would think about a storage shed or garage for the whole tractor, not just the cables.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
what he said....
K thanks, I will look at marine products. be nice if I could marry a marine cable to the OEM throttle lever and that should be doable.
Have you ever tried using "chain and cable spray" ? I believe it's made by " Lubriplate". It works great on motorcycle cables and chains. I also used it for my hood release cable for the car. Speedometer cable .
thanks gary I will add that to my spray cans shelf...
When they get tight I just soak them with a similar product, and they always release.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
I figured there might be generic stainless cable since I will have to try to reattach something anyway. I want to save the throttle control.
I have the same frozen/seized cable issue on a 100 myself. I am planning on using an ultrasonic cleaner and then high pressure air. Lastly I’ll soak it down internally with motorcycle chain lube
livin the cub life ![]() ![]() ![]() ![]()
If I had covered the tractor with a tarp (loosely to keep the moisture from accumulating) it wouldnt have stuck at all. Im still for getting a marine or stainless cable and never have the issue no matter what
