Old 11-24-2021, 08:49 AM
Tagcab7 Tagcab7 is offline
Thanks for the advice, I’m soaking it all in. Anybody ever try an ultrasonic cleaner? I don’t think I’d buy one just to do a carb or two, but I’ve heard good things about them.
Old 11-25-2021, 08:01 AM
ironman's Avatar
ironman ironman is online now
I got one a few years ago specifically to do these carbs.
They are expensive so the one I got was just big enough to hold small carbs. It cost about 35 bucks.
To say I was disappointed with the results of its cleaning would be an understatement. It sucked!.
Then to boot, it just quit working about the 4th time I used it. It was a Chinese product of course.
My advice is, keep your money.
Old 11-25-2021, 10:23 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Agree with Ironman.
I got one to clean gun parts. I was underwhelmed and gave it away.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-28-2021, 10:25 PM
Agree with Ironman.
Good to know. I won’t waste the time or money. I ended up finding a #30 carburetor. From what I read here it will work in place of a #26 so I put it on and had it running today.
Old 12-27-2021, 09:39 PM
Thought I’d do an update. After messing with the #30 carb for awhile I ended up ordering a new one. It ran decent with the #30 but I couldn’t quite get it dialed in. Could’ve been me or maybe some junk still in it since I didn’t take it completely down to clean it. Ran in to the same issue with removing the main jet and decided to leave it alone this time. The choke operating backwards was pretty annoying too. I ordered one from isavetractors. I had a $30 gift card so it ended up costing $30 after the card. Put the snow blade on today and ran it around some. Thank for all the help.
Old 12-28-2021, 10:19 AM
Tag, you still have the #30?
For sale by any chance?
You didn't screw it up I hope.
Old 12-28-2021, 10:40 AM
You most likely won't, it is too big.
Old 12-28-2021, 07:59 PM
Yep, still have it. It had some issues when I got it that I should tell you about. The main jet backed out easily until it got a ways out but then stopped. I think some messed up threads in the emulsion tube. At that point I just screwed it back in and let it be. The choke plate has a mounting screw broken off in it so it’s held on by one screw. Lastly the bolt that holds the bowl on is finicky to get started. If your still interested in it I can send you some pictures. The throttle shaft is in good shape IMO.
Old 12-28-2021, 09:55 PM
A 102 should have a # 26 carb not a 30, prolly why you can't tune it in.
Old 12-30-2021, 08:58 AM
I thought I had read somewhere that they would interchange. Apparently not though. Another lesson learned.
