Old 11-25-2021, 11:52 PM
Wntsom4 Wntsom4 is offline
Default 1250 Electrical connections
Is there a location to purchase just the electrical connections to the gauges, light switch, and ignition?
Everything works
I see a hot spot on one connection
Considering making my own new wiring harness but need to find these connections for my 1250.
Any part numbers listed as I don’t see just the connections as only an option
Old 11-26-2021, 06:51 AM
There are two ways to go.
(A) There is the inexpensive practical way to and get universally available terminals.
or
(B) Emulate OEM. It may a little difficult to find and cost more. The terminals can be found but the Molex Housings may be more difficult
OEM used 16 GA wire.
Old 11-26-2021, 09:00 AM
Auto parts store should have those.
If the plastic connector housings are not burnt or melted you should be able to reuse them once the wire terminals are removed.
https://www.delcity.net/store/Packar...nectors/p_9108
I get all my wire supplies here.
You can order as many or as few as you need.
You should use the correct crimping tool for best results though and they are not cheap.
Good luck!
Old 11-26-2021, 09:38 AM
CubDieselFan's Avatar
Here is another option. Get a new harness.
http://www.porchelectric.com/ihcub.php
Old 11-26-2021, 03:48 PM
Thanks for the info.
I was just wondering if the CCS or The other vendor mentioned were worth it or build my own. Just want to know what’s worth the time being everything I’m doing to by 1250 is being renewed and repainted. Didn’t want 40 year old wiring in this updated tractor.
Old 11-26-2021, 06:40 PM
mortten mortten is offline
They aren’t Molex connectors. They are Packard 56.
Doug
QA-36A
42" blade
Old 11-26-2021, 06:45 PM
https://www.ebay.com/itm/382231331196
Old 11-26-2021, 06:51 PM
Porch Electric is No Longer in Business.
Old 11-26-2021, 07:43 PM
Their website is still up. I sent them an email to be sure.
Old 11-26-2021, 08:53 PM
Porch still has ads up on a certain auction site.
Doug
QA-36A
42" blade
