Old 11-12-2021, 10:23 AM
I looked up the 2 camshaft part numbers and there doesn't seem to be any difference between the 2... perhaps Kohler changed the part number for the camshaft somewhere in the production run?
This can be easily found out if the owner of the engine, would supply the Kohler "spec" number.
Old 11-12-2021, 10:24 AM
Cubcadet_107's Avatar
Thanks Roland
Jim, look at the serial tag on the engine for the spec number. Assuming the engine is the correct age for the tractor it came from the tag should look like this...
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 11-12-2021, 06:34 PM
Carpetbagger Carpetbagger is offline
Default My best guess
My best guess on your problem is compression related. Pull the plug and turn the engine over. If it spins really fast, but continues to slow or stop on the compression stroke, pull the half moon shaped cam cover and check for a broken or disconnected spring on the compression release mechanism. Let us hear what you find out. Carpetbagger
Old 11-12-2021, 07:34 PM
Jim in SC's Avatar
Jim in SC Jim in SC is offline
I'm pretty much beyond that now - I'll be pulling the bearing plate, crankshaft, etc. this weekend. The ACR has it's spring, but it's got a broken tab. New camshaft is enroute here now.
1951 Farmall H; 1957 Willys CJ5; 1959 Farmall Cub; 1961 Cub Cadet Original; 1963 & 1964 Cub Cadet 100's; 1971 Cub Cadet 106
Old 11-12-2021, 07:48 PM
Jim in SC's Avatar
Originally Posted by Cubcadet_107 View Post
Thanks Roland
I wish I could. Th PO had a PO had a PO, etc. The tractor was painted black & yellow when I got it if that tells you anything. As far as a SN tag and spec# - it had one, but it had been "cleaned" with sandpaper, as far as I could tell. Virtually unreadable. The closest I could make out was SN A918098, Spec 46858. I can't verify that though. Here's a picture of the blower cover with tag when I got it:
Old 11-12-2021, 07:53 PM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
Looks like you got the PTO assembly off. Hard part's over
Old 11-12-2021, 08:10 PM
Jim in SC's Avatar
LOL. Yeah, with the help of a gear puller and impact wrench! No damage though...
