I have a 2016 XT3 GSX with 60inch deck. Went out to mow a couple of days ago. Lower the deck (electric) and it was fine and mowed. Upon completion the deck won't go back up. With the engine off and the key on, when you toggle the switch the actuator is engaging but there is no movement in either direction. Anything to look for? Visual inspection of what I can see there is nothing. Thanks!!!
Dead or weak battery
I'll bet the power steering didn't work either. |
Battery is new and power steering is fine.
OK, loose wires or bad switch then, or defective actuator.
Good luck |
I have seen people talking about this issue and new relays fixed it for some people. A good diagnostic test is needed instead of throwing parts at it.
Thanks for all the input. Have a little time now, mowing season is over.
