Old 04-03-2015, 11:50 PM
Unconventional Unconventional is offline
Default 1962 Original input shaft seal
I need to replace what I believe is the input shaft oil seal in my Original. It is at the end of the shaft toward the rear of the tractor. How do I remove the shaft and who has a good seal for it? It has been sitting like this for awhile and I have filled up a good size cup full of gear oil. I would like to get it fixed and out of the way as soon as possible. Thanks
Old 04-04-2015, 12:25 AM
Are you referring to this seal?
Old 04-04-2015, 11:49 AM
Yes that looks to be it. Its right behind the round rubber pad on the shaft.
Old 04-04-2015, 01:18 PM
You can view the service manual for the original on how to remove. 2 bolts on left side, one bolt on right side, remove clutch actuator shaft, and 2 bolts at flex coupler, drop out drive shaft and clutch as a unit. Drive out spiral pin at input shaft and remove coupler. Put a couple screws in the seal and pull out with vice grips. I would make sure you don't have a lot of play in the input and inspect input shaft for scoring. Both of which will make it leak. Here is a pic of clutch you will be removing. You can take out entire rear with 4 big 3/4 head bolts and disconnect brake linkage too but I think this can be done under tractor with rear in place just as easy.
Old 04-07-2015, 09:44 PM
Thanks for the walk through. I have got it all torn down and ready for the new seal to go in.
Old 10-17-2021, 05:12 PM
That_cub_dude1847 That_cub_dude1847 is offline
Attachment 63699
When Installing the seal, should I put any sealant around it?
Old 10-17-2021, 06:56 PM
no sealant is necessary.
Up to 530 and counting...
