Old 10-13-2021, 09:47 AM
Sc120sc Sc120sc is offline
Default K321 head and tin assembly
I posted this to the forum before and never got a definite answer. Assembly drawings DO NOT help
I need to know how to assemble the head and cowling on top of my k321 like the gas tank mount etc.
Mine has head studs which are still in plus a few head bolts. I need to know where any spacers go. I found 4 spacers. I think I have everything needed to put back together. A picture would help.
Old 10-13-2021, 12:03 PM
You make NO mention of the Tractor Model you are working nor the complete Kohler Model either.
Old 10-13-2021, 12:55 PM
Tractor. 147. Engine K321. Engine number mentioned twice in thread
Old 10-13-2021, 04:55 PM
A accurate and complete Kohler model number would be like this: K321-60226. This fine tunes and can accurately answer your question(s).
Old 10-13-2021, 06:30 PM
Its K321 A. Looks like 2257311 maybe
Old 10-13-2021, 08:54 PM
athomas's Avatar
athomas athomas is offline
Hope these pics help ! this engine has all bolts ,but if you got studs usually there would be a spacer over the stud to fill the void in the head then your tin baffle would sit on top of the spacer then the washer and nut ! these studs would all be out in front of the fuel tank mount which sits on top of the large blower housing !
Old 10-15-2021, 09:27 AM
So if I understand correctly my engine has 5 studs and 5 bolts. My studs are all on the blower housing side.(So I need FIVE spacers??) The stud nuts are torqued along with the head bolts AFTER fuel tank mount is in place?.
Old 10-15-2021, 10:24 AM
Pictures of what you have such as the top tin and muffler shield would help.
Up to 534 and counting...
Old 10-15-2021, 02:34 PM
athomas's Avatar
I've not seen studs on the fuel tank mount unless someone changed something , pics of your tins and head would help as Lew indicated .I believe the most studs I've seen in a head is maybe 2 or 3 but that doesn't mean someone couldn't add more ?
Old 10-15-2021, 06:43 PM
I will get a pic but correction. I have 4 studs and 5 bolts and 4 spacers
