Old 08-17-2021, 09:19 PM
SS5150's Avatar
SS5150 SS5150 is offline
Default Diff Carrier Bearings
Anyone have a cross reference for Cub Cadet 741-0369 and 741-0400? They are the rear diff carrier cone and cup for Original through 2182. I've got a fine spline carrier with damage to the cone & cup on the ring gear side so I'd like to replace both sides if I could.
Thanks
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 08-18-2021, 07:22 AM
Make sure you check the lash between the ring and pinion and re establish it with the new bearings installed. otherwise it will howl about 45 MPH.
But seriously it needs to be within range, or excessive gear wear will result.
Old 08-20-2021, 12:15 AM
Dart1917 Dart1917 is offline
Get them out and the numbers should be on the parts. Probably Timken.
