Old 06-09-2009, 09:57 PM
jfinney's Avatar
jfinney jfinney is offline
Default Timing site hole
Ok, so this is going to be a very stupid question. I want to check the timing on my K161 and I don't know where the site hole is. I've read up on how to time the system, but am not quite sure where to find the site hole. I read that it is on the starter/generator side of the tractor on the bearing plate, but I don't know what that is. Do I have to take anything off of the engine to get at it? Does anyone have a picture of where the site hole is and what it looks like? Thanks for your help.
Jason
Old 06-09-2009, 10:35 PM
JayBrd's Avatar
JayBrd JayBrd is offline
It should be on the generator side between the block and the flywheel shroud, 1/2" or so hole on the side. If you can't find it I can post up a quick pic on mine...
Old 06-10-2009, 06:54 AM
What model of Tractor are you working on...???
Old 06-10-2009, 08:13 AM
jfinney's Avatar
It's a model 73. Is the site hole in different spots on different models even though it's still a 7hp engine? Thanks, Jason
Old 06-10-2009, 08:30 AM
MBounds's Avatar
MBounds MBounds is offline
JF: A K-161 is a K-161......Seems to me a Service Manual would help a lot...
Myron B
Old 06-10-2009, 08:35 AM
jfinney's Avatar
Myron,
Does the service manual have a picture of where the site hole is? I have a small engine repair book that tells me how to set the timing, but I don't know the terminology of engine parts that well. As such, I wasn't quite sure of where the bearing plate was. Believe me, I know the value of the service manuals, I have one for my 1250. Thanks, Jason
Old 06-10-2009, 11:57 AM
jfinney's Avatar
Wild Bill,
Thank you, I found a picture of the location of the site hole on my 73. It looks like a pretty small cover in a not very conspicuous spot. Thanks to all for your help.
Jason
Old 06-10-2009, 12:10 PM
ajgross ajgross is offline
Inactive Member
Now that you've found it, shoot a little bright colored spray paint into the hole at the timing marks so you can see them.
AJ
Old 06-10-2009, 07:22 PM
On my 71 and all of my Originals the timing hole is right behind the starter/generator at just the right point that you can't possibly see through it, unless you start the motor, loosen the S/G belt, flip it off and rotate the S/G down out of the way.
Old 06-10-2009, 09:37 PM
jfinney's Avatar
yosemite sam,
Funny you should say that. I came home from work, found the hole, and thought, "How am I supposed to see in there with the starter/generator on?" Thanks for the tip. Jason
