Hello gentlemen,
I have a 1974 IH Quietline that has a blown head gasket. I have ordered the replacement but my question is. With these original 10hp Kohler engines do I need to tourque to specs when putting the head back on? Or can I just tourque down to tight? Any help is appreciated. Thank you
Proud Owner of a '74 Quietline 1000 series, #2 Cart, and a mid 70's?? IH Cub 265 snowblower. |
Yes, definitely do torque the head bolts to spec. Spec is in the range of 30-35 ft-lbs, 30 will do just fine. Be sure to look at the tractor service manual and find the head bolt torque sequence, and follow it!
Before you put it all back together, I have a recommendation. Because you blew the gasket, you may have warped the head or it was already warped and caused the gasket to blow. The way to remedy this is to take a piece of 220 grit sandpaper, and set it on a flat glass plate, then sand the surface of the head down until it is flat, making sure to keep a random sanding pattern so it works evenly. With the head on a flat surface, you should not be able to stick a .003" feeler gauge under the head in any area. Once back together, run the engine for a couple hours and then re-torque the bolts to 30 ft-lbs again. When you replace the head gasket, it compresses and the head bolts will loosen slightly. Re-torquing them will remedy this.
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
Per page 12.16 of the K Series Service Manual.
Thank you all for the help. Any idea where I can find the specs at for the bolt pattern when I torque it back down? This is the orginal Kohler 10hp.
![]() Quote:
102 ![]() |
Before you start, go here and read this.....
https://www.onlycubcadets.net/forum/...ead.php?t=5656 |
Thank you all. I was able to replace the head gasket and it fired up perfectly. I appreciate all the help as always
This is what I did when I replaced the head gasket on my K161 for my 73:
-Sanded head flat on a piece of glass using Matt G's advice. -Decarboned head/top of block -Checked block deck for flatness with a straight edge. -Oiled cylinder wall -New gasket with copper coate -New head bolts - a drop of oil before install. -Torque specs are 15-20 FT LBS for this head, started with 15. -Ran for 20-30 min, made it work a small bit (driving it around, taking off in third gear with my fat butt on the seat) -After the engine cooled off (like next day) tightened the head bolts to 20FT LBS in the proper order 2-3 times making sure they were tightened properly.
