Old 04-15-2021, 10:59 AM
RLause's Avatar
RLause RLause is offline
Default Trunion springs specifications
Does anyone know what the specifications are for the trunion springs. It seems like I have seen the information before, but doing a search on the web and on here turned up nothing. I would like to test mine before I order new ones. Thanks in advance for any help.
Richard
Old 04-15-2021, 11:08 AM
cooperino's Avatar
Not sure I have ever seen a spec as in how many pounds of tension etc.
Old 04-15-2021, 11:21 AM
Can't say that I have also.
Old 04-17-2021, 09:35 AM
Workingstiff Workingstiff is offline
Why do you think you need new?
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 04-17-2021, 09:53 AM
poellot poellot is offline
I cannot tell you specs. But... there should be just a very little compression to put them in. With new springs it only takes your fingers to compress enough to get them in. The middle spring compressed first until the outside spring contacted, then just about 1/16 to 1/8 tops i would say on my new oem springs when putting them in.
Old 04-17-2021, 03:39 PM
RLause's Avatar
My 782 seems to jerk more than it should when I shift from forward to reverse. Shifting from reverse to forward seems to work smoother. The trunion corners are in good shape and the springs look OK.
Richard
Old 04-18-2021, 07:16 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Turn the spring around and see what happens!
Plow blade
#2 Cart
QA36 snowthower
