Old 04-08-2021, 05:20 AM
pinehillian's Avatar
pinehillian pinehillian is offline
Default Degreasing, yes or no?
hi all,
My 1998 1641 Vangaurd motor, needs spring tune up, motor is pretty dirty. I was thinking a can of Gunk and a garden hose. I have no air breather assembly, top of flywheel vents and some wiring behind dash areas are vulnerable to moisture. Any suggestions on do's or don't s. any help is appreciated,
Pine
Old 04-08-2021, 08:25 AM
I wouldn't hesitate to give it a good power washing with caution. Any place you could get water inside the engine I would seal off. Places where wiring plugs are exposed I usually wrap em in plastic wrap and Gorilla tape so they stay dry. If you look at something and think "I don't think that should get wet" wrap it. Then wash away.
Good luck.
Ken
Old 04-10-2021, 02:15 AM
Default degreasing
sounds good, probaly powerwash it thanx
Old 04-11-2021, 08:14 PM
Good luck.
Ken
Good idea. I've used GUNK on my tractors with success. Cover the points cover and any exposed wiring first and that allows it to run once it's been rinsed off.
Old 04-12-2021, 09:16 AM
You HAVE NO AIR CLEANER???!!!
What up with that?
