Been looking at the mini tire changer at Harbor Freight, watched some videos, etc. Does anyone have experience with this unit specifically will it work with the wide tires used on the supers? They say up to 12" rims, but the unit doesn't look big enough for the wide tires.
I have use one many times but always on the smaller front tires. I don't
think it will do you much good on the bigger rear tires. It is a bit of a learning curve, lots of lube is you friend for sure, and a bit of muscle. I have more then got my money out if it though. Pretty handy little tool. Ken |
I used mine to break the bead on a 26/12/12 from my Kubota. Worked fine for that but can’t say if it will change a tire that wide.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
Thank you Ken and Adam. 26 12 12 is the same size as the super rears, no? Im going to go ahead and grab one next time I'm there, even if it wont to the rears, it'll take care of a lot of other equipment I have around here.
I use the mini for front tires and the regular tire changer for the rear tires. If you have room for both that's the way to go.
Current: 102 122 SZ60 Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265 |
I have the Northern tool equivalent at work. I have modified it some, after bending the factory threaded rod, I drilled and tapped to 5/8. As well as added some length to it for the bigger stuff. Mounted on some scrap stand I found.
I have a full size powered changer also. But this works well for front tires on zero turns. |
Bought one, and it broke on the first try. If your tires are new and not stuck and rusted to the rim, then MAYBE. Otherwise to me, it was junk.
I've had one for several years. I used it this week to fix a flat on my 1641.
Cannon |
