Old 02-19-2021, 05:19 AM
japatten71 japatten71 is offline
Default 149 Cub Cadet Choking Problem
Hi guys
I got a 1971 149 cub cadet. My problem is that it will only start and run even after being warmed up at full choke. If you strat to push the choke in the engine starts puttering and then will die usually within 10 secs or so. I do know that if the fuel is not shut off after use gas will leak out of the carburetor. I do not know if these two things are connected. So my thoughts are the float is messed up and that why it leaks fuel but I have no idea why it will only run fully choked.
Before I tore into my carburetor wanted to check here if anyone has any idea of what could be wrong.
Thanks
Old 02-19-2021, 08:03 AM
If it is leaking/flooding, the needle valve/inlet valve controlled by the float is either worn or has crud/chit under it.
And the fact that it runs better chocked indicates it has partial blockages in the internal passages.
Take it off and clean things inside.
Make sure you remove the emulsion tube and clean up the many small holes in it.
If it is original/unmolested, best to get a inexpensive carb kit that contains a needle/seat and a few gaskets.
Some find it beneficial to soak in pinesol a day or so.
Use your air hose to make sure the fuel inlet elbow is clean by blowing both ways.
Upon re instillation, make sure you have a good fuel flow from the fuel tank before you carefully insert the fuel line paying attention not to allow the inside of the fuel line to introduce more chit/crud into yer clean carb.
Adjust idle speed as well as slow air bleed and high speed main jet as per service manual you downloaded free from here.
Old 02-19-2021, 08:04 AM
Billy-O's Avatar
Billy-O Billy-O is offline
You prolly got crap in the carburetor that's messing the float and blocking the orifices. The float has little/ nothing to do with carburetor tuning...it merely regulates the level of fuel in the bowl. With fuel in the bowl, the carb meters proper fuel and air mixture to the engine.
Pull the carb and clean it.
Plow blade
#2 Cart
QA36 snowthower
Old 02-19-2021, 09:51 AM
I would also pull the gas tank and spiffy it all up. Replace your fuel lines as well ( cheap insurance). It doesn't do any good to get your carb all cleaned up and then send junk from your tank right back into the carb. Once you get that all done you have eliminated that variable for any problems down the road.
Good Luck
Ken
