Does anyone have a pic of the front belt tensioners. Mine look crooked. Should they be parallel . I can't figure how to upload a pic.
Assuming you're talking about mower deck idler pulleys- no, they angle back to the right if you are looking at the front grill of the tractor. I think individually each pulley is at a slightly different angle.
I don't have a mower mounted right now to get a good pic for you.
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
![]() Quote:
My dad had problems with the angle on those pulleys on the mule drive. He would only get about 3 mowings before the drive belt shredded itself. When it first happened, he thought it was an old dry-rotted belt, but when the replacement did it again after 3 mowings, I knew we had a problem. With yet another belt mounted, I took the look at the path the belt took. Eyeing up the belt as it passed over the pulleys, I could see the right one had a twist and the was pointed toward the rear tire. I was misaligned so much the belt was riding up out of the sheeve as it left the pulley. I took 2 adjustable wrenches and with them adjusted to hold onto the swing-arm for the pulley and with one up near the swing point and the other down near the pulley, I "adjusted" the angle on the pulley so it was pointed toward the drive pulley on the deck. I did the same sightly on the other mule drive pulley. So far, he's gotten 2 seasons with the same belt - big improvement. I don't know how the arm got twisted, maybe it got hit with something while doing other yard work with the tractor. IDK....
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
They both should be bent to the right for a 44C, or 50c deck. The 38C should be straight.
Thanks, dad had a 60" deck. I don't know how the one arm got really twisted, but it was really off the mark and pointed to left field when he asked me to look at it.
Thanks for the info
