Old 12-01-2020, 02:54 PM
lakeerie1 lakeerie1 is offline
Default Year unknown
I'm trying to find a replacement ignition switch for my Cub Cadet Model 1250. My switch has 4 stabs whereas all the ones I find on the internet are 3 or 5 stabs. To get to the correct engine diagrams I need my model's year. My serial number is 2050630U638629. Can anyone tell me what year this is? Also, I am being prompt to add more numbers to the 1250. Thanks!
Old 12-01-2020, 03:13 PM
Cubcadet_107's Avatar
Your tractor was built in October 1978. The last 6 numbers on your S/N, 638629, determine this. The rest denotes the model of tractor, which is indeed a 1250. The "U" means built in the US.
Hope this helps
'70 107 with k301 engine swap
'71 106 with 38" deck
'63 70 "pinkie"
1863 with 54" deck
105 x2 (parts)
Old 12-01-2020, 03:43 PM
IH-61524-C3
IGNITION SWITCH
This part replaces IH-61524-C2.
Old 12-01-2020, 04:27 PM
ironman's Avatar
ironman ironman is online now
Like this....
https://www.ebay.com/itm/Cub-Cadet-I...Cclp%3A2334524
Old 12-01-2020, 05:42 PM
Keep the tractor under cover when not in use to avoid such problems in the future,
Electronical equipment does not like moisture.
A dab of dielectric grease on the terminal spades may aid as well.
Old 12-01-2020, 08:36 PM
Wow,guys! Exact, accurate answers in no time at all. Glad I found this forum. I hope I can be a contributor in the future. Thank you very much.
Tags
ignition, serial number, switch
