Old 07-14-2020, 10:27 PM
Good looking 107, you have there!
Old 07-18-2020, 11:00 AM
twoton twoton is offline
Got a piece of chrome-moly to make a new idler pivot shaft for the mule. And yup, I free handed it.
Old 07-20-2020, 10:17 PM
Farmall450's Avatar
I pulled the old fuel pump from the 1711. Ordered some parts, and will be waiting for those.
Old 07-27-2020, 10:48 PM
IHCubCadet147's Avatar
I polished my 125.
File Type: jpg FA95549E-CC57-440B-A544-6BE78B0ECB38.jpg (25.7 KB, 196 views)
File Type: jpg 54E299DA-9EC6-433C-B63E-41FA0C1451E0.jpg (28.0 KB, 196 views)
Old 07-30-2020, 10:34 AM
coakes00's Avatar
coakes00 coakes00 is offline
After years of wanting to, I finally had the right stuff to try out plowing. Special thanks to Jeff in Pa for building the sleeve hitch and all the members that help me with my cub questions. I spent 3 hours messing with the Brinly to get it set and only got it to go in when tipped way down. We have an old simplicity plow that's sat as yard art for years so figured I would give it a try. Scoured it up with a flap disk and put some shims in the pen. I was amazing the first pass with it went better than the final pass to the Brinly.
File Type: jpg Screen Shot 2020-07-30 at 8.32.10 AM.jpg (29.3 KB, 179 views)
File Type: jpg Screen Shot 2020-07-30 at 8.31.54 AM.jpg (23.0 KB, 179 views)
File Type: jpg Screen Shot 2020-07-30 at 8.31.39 AM.jpg (49.3 KB, 177 views)
Old 08-01-2020, 04:25 PM
Hairtrigger's Avatar
Hairtrigger Hairtrigger is offline
Default The addiction continues
A year and a half ago I needed a garden tractor for a small wooded property that I have I bought in 1864 by accident. It came with a mower deck snowblower and Sims cab
The tractor really impressed me and I found another one for sale locally so that made number two now the addiction has begun.
After enjoying those two tractors I realized I really like the looks of the red Cobb cadet, today I found a 782. It came with an extra motor and most of the pieces needed for the deck. I do not think the deck will ever get mounted onto this tractor again.
File Type: jpg D0D37806-A789-43E9-BC95-3207626E4788.jpg (27.4 KB, 163 views)
File Type: jpg 44FFED20-5590-4E25-9CAD-0926E122F469.jpg (30.5 KB, 164 views)
Old 08-01-2020, 07:50 PM
mortten mortten is offline
Put some new V61’s on the 1250 today.
File Type: jpeg 7F3CF034-0774-41E8-B539-BA2A3A0F7AFE.jpeg (59.5 KB, 160 views)
Doug
QA-36A
42" blade
Old 08-21-2020, 11:06 PM
Last week when I was mowing with my 129, one of the tie rod ends came apart. Tonight I replaced it with a good used one I had. All ready to cut grass tomorrow!
Old 08-22-2020, 10:33 AM
snoel's Avatar
snoel snoel is offline
Default Cc 1000
In the last week or so, flushed fuel tank, installed new fuel shut off, fuel line, fuel filter, and had new carb kit installed. Now need a good wash . It has set outside for over two years, that I've had it. Starts and runs great.
Steve
Old 08-31-2020, 10:17 PM
Farmall450's Avatar
I pulled the blown KT17 Series II out of my 1711 and got it ready to receive the donor CH18S.
