Old 02-01-2020, 09:11 AM
jbrewer's Avatar
jbrewer jbrewer is offline
You could always put tubes in the originals too, if you wanted.
There's a LOT of repainted new shiny cubs , and they're very nice looking, but there's only ONE that looks like the one you have. I think it's great that you're keeping it that way, showing that it's earned it's patina!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 02-01-2020, 09:19 AM
dads70's Avatar
dads70 dads70 is offline
good idea I hadn't thought of on just using tubes in the orig 2 ply firestones...…. think ill get a pair hopefully I can break it down and install without the tire falling apart
Old 02-01-2020, 09:26 AM
dads70's Avatar
it is a huge pain to install tubes? what tools do I need?
Old 02-01-2020, 09:28 AM
jbrewer's Avatar
You should be able to just break one bead off the rim, and stuff a new tube in without a big problem!
Hint: Put soapy water on it before you start doing this :-)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 02-01-2020, 09:31 AM
dads70's Avatar
good advice, I think ill try tubes ebay has a pair for like 14.00 would like to keep the original rear tires if poss
will be getting a light wiring kit to hook all of them up very soon will be posting build and maintained pics here will stay patina just oiled lubed and washed will live inside my shop with a cover
Old 02-01-2020, 09:32 AM
jbrewer's Avatar
Here's how I break the bead
Remove valve core .
Place 2x12 piece of wood, or sometimes I use one of my drive on car ramps right on the edge of the bead near (but not ON the rim).
Drive car up the ramp till bead pops off the rim.
Done!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 02-01-2020, 09:34 AM
dads70's Avatar
AWESOME IDEA SHELL EITHER COME OFF OR COME APART
Old 02-01-2020, 09:47 AM
dads70's Avatar
I have a line possible, on a IH cart to pull behind for firewood, and lawn tools. Hopefully pics to follow.
Old 02-01-2020, 10:16 AM
jbrewer's Avatar
when the rim is flat on the ground, try and get the business end of whatever you're driving up on RIGHT on the seam where the tire meets the rim (two people helps this... you dont want to bend the rim).
I've done this a bunch of times and it's always worked...
Also, it helps when putting the tube in, if you let it sit in the sun and soften up some before wetting it with the soapy water and slide it into place.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 02-01-2020, 07:43 PM
IHCubCadet147's Avatar
IHCubCadet147 IHCubCadet147 is online now
Looks nice! Glad to hear it made it home safely.
