Old 01-25-2020, 01:56 PM
Yugosouth Yugosouth is offline
Default Hood needed for 2005 Cub Cadet GT2542
Needing a good hood for a 2005 Cub Cadet GT2542. Just need the plastic hood. The hood opens from the front of the mower. I have all of the metal parts that caused the hood breakage, so don’t need that . Price and location please. I am located in north central Alabama, 35776.
Contact me by email at: Yugosouth@aol.com
Thanks, David.
Old 01-25-2020, 03:39 PM
Do you have the new improved design? That was a huge issue on the original design and almost all of them broke.
Old 01-25-2020, 04:38 PM
Default Hood...gt2542
Don’t know if it’s new design or not...it’s broken. If that was the improved design, someone didn’t think it through too well. I do know that it’s the original hood, as my ex bought the mower new in 2005. It’s only got 144 hrs on it, always been garaged, covered, and maintained each season by the dealer in Tuscaloosa, Al. It had the cylinders at the rear edge of the hood, and broke out the entire rear edge. I’m going to put some hinges at the rear of the replacement hood instead of the garbage that was there. Likely will last a long time.
Old 01-25-2020, 06:39 PM
msmitty msmitty is offline
is the hood off super LT 1554 the same ? from what I can see they are---I have one for super LT1554
Old 01-25-2020, 07:25 PM
Shipping will be killer, more than 50.00
Old 01-25-2020, 08:17 PM
Default Hood gt2542
Has anyone attempted to compile a list to determine which hoods will interchange from one series to another? As an example. : Would most hoods from
the 1000 series interchange to other 1000 series mowers? Do some interchange from this series to the 2000 series? And so on... I had the same problem with the green machines hoods. Didn’t buy a used based on no one having a clue as to what would or would not interchange .buying item on a guess doesn’t work.
Old 01-25-2020, 08:19 PM
Default Hood gt2542....
Msmitty"... thanks for the insight on hood interchange. Guess I’d better be sure before I pull the trigger..
Old 01-25-2020, 08:49 PM
IHCubCadet147's Avatar
At the top of the page, click the “Cub Cadet Parts and Service Look Up” link, click the box with the Cub Cadet logo, and type in the two model numbers. See if the two hoods have the same part number.
Old 01-25-2020, 08:57 PM
Thanks for that information. I’m new to the forum, and still need to learn about navigating the site.
Old 01-29-2020, 07:38 PM
the hood I have off lt1554 you could have for shipping--has one small crack on bottom front lip
