I need to rebuild the brake pads on a couple tractors. What are you guys using for new pad material? Thanks
I have bought brake material from McMaster-Carr for other projects. They may carry something you could use. Their website is one of the best to navigate.
I've used the metal-free brake and clutch lining that McMaster-Carr sells. It's a little thicker than original but can be sanded down a little ! There are a couple widths and lengths available, can be cut with utility knife or thin cut-off wheel. Then clean off old stuff, wire wheel, or blast. I think I used like a JB Weld type adhesive at the time to bond to the pad holder.
Here ya go....
use the 3/16" thick. Yes, it will have to be thinned a bit. You can use JB Weld to adhere it. https://www.mcmaster.com/brake-lining |
Thanks guys! Good info!
