Old 10-26-2019, 10:05 PM
Rwgarrison23's Avatar
Rwgarrison23 Rwgarrison23 is offline
Default 3 speed manual transmission leak.
1969 cub cadet 124.
Trying to figure out my transmission leak on my 124 3 speed manual transmission. Earlier in the month, I replaced the o ring that goes on to the wet brake push rod and lever and the axle seals that solved it but I have a leak from where the drive shaft coupler meets. Is there another o ring sit behind that coupler?
Old 10-26-2019, 10:12 PM
sawdustdad's Avatar
There is an oil seal at that point.
Shouldn't leak a bunch at that point as it is above the oil level. But certainly could produce a drip or two Should not leak continuously while sitting still.
Seal, Reduction Drive Shaft Oil
Part# IH-385076-R91 (Superseded to IH-385076-R92) 
OEM Warranty Repair Part for Cub Cadet
#20 in the diagram
Old 10-26-2019, 10:20 PM
#20 in the diagram
Well, my worn out clutch is currently spinning some. So I have a brand new drop in clutch assembly that I'm going to be putting in shortly. Maybe this will help stop having drive shaft spinning some while just sitting. Parking brake on. Is this seal behind the plate?
Old 10-27-2019, 09:49 AM
Cub70's Avatar
Cub70 Cub70 is offline
Before you spend $300 for that awesome clutch set up, does your current clutch have these 3 anti rattle springs on the clutch fiber disc? If so, take them off or cut them off, these anti rattle clips can and will cause your drive shaft to spin when the tractor is in NEUTRAL with the engine running. They will also allow the drive shaft to continue to spin once your depress the clutch pedal, causing a slight grind of the gears when you select your next gear. These springs were designed as an anti rattle solution, but was a flawed design. What they ended up doing once installed
or with time, was allow there to be a slight drag/bind of the fiber disc and the small pins on the 3 pin disc plate.
Also, if you don’t have those 3 springs, the center bearing on the 3 pin clutch can be worn out or not have enough lubricant. These will also cause your symptoms listed above.
1964 Cub Cadet 70 (Full Restoration), Upgraded/Rebuilt K181 8hp engine, custom exhaust stack/flapper, NEW clutch, brand NEW steering column, Custom made wiring harness w/ammeter, LED headlights and tail light, Custom 2” receiver hitch, Custom pull behind paint matched trailer
Old 10-27-2019, 10:25 AM
sawdustdad's Avatar
Cub70 is spot on. Also, did you try to adjust the clutch? There is a screw that takes up slack in the linkage, Under the dash tower, at the bottom of the clutch actuator arm. Might be all you need.
The seal should be in the plate. Never replaced one myself, but should be able to do it without disassembling the reduction housing.
Old 10-28-2019, 08:34 AM
Workingstiff Workingstiff is offline
Attachment 102259
GREAT info,thanks!
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 10-28-2019, 10:01 AM
Very good information. My clutch assembly is worn out. My driveshaft itself have a groove in it, the throw out bearing making awful noise, the lever where it holds the bearing is loose and worn out. So, dropping a new assembly in seem wise to me. Dont use the spring on the new set up?
Old 10-28-2019, 12:41 PM
ironman's Avatar
ironman ironman is offline
YES..... plus 7 more characters
Old 10-28-2019, 07:32 PM
Cub70's Avatar
No! Don’t use the anti rattle springs on your new clutch assembly!
Old 10-28-2019, 08:50 PM
The repair manual says use them as needed, I always put one on, not three though...
Yeah I would not put them on that setup.
