Old 10-26-2019, 09:20 PM
Rwgarrison23's Avatar
Rwgarrison23 Rwgarrison23 is offline
Originally Posted by sawdustdad View Post
There is an oil seal at that point.
Shouldn't leak a bunch at that point as it is above the oil level. But certainly could produce a drip or two Should not leak continuously while sitting still.
Seal, Reduction Drive Shaft Oil
Part# IH-385076-R91 (Superseded to IH-385076-R92) 
OEM Warranty Repair Part for Cub Cadet
#20 in the diagram
Well, my worn out clutch is currently spinning some. So I have a brand new drop in clutch assembly that I'm going to be putting in shortly. Maybe this will help stop having drive shaft spinning some while just sitting. Parking brake on. Is this seal behind the plate?
