After doing various searches with CL/Facebook & talking with Cooperino I came across this find. The 1450 is not currently running so i have to dig into it.. unfortunately i didn't get a key with it.. arg I was told the last time this thing was running was 8 years ago.. I pulled the dipstick on it and it looks like brand new oil..he threw in the snow thrower, he didn't know if it would work for the 1450 or not...
So question is who would be available to help me with some (1450) key(s)?
Cub Cadet Specialties should have that key, along with a couple of new flex disc joints. That front one looks like it's ready to come apart.
Good save on the 1450, and rear lift too! |
Since we spoke and you told me what you paid, you did real good at first glance.
However, do what I told you with the tank and fuel system before you do anything. Check over that tractor thoroughly before turning your new key. If you get it to turn and actually start DO NOT RUN IT FOR MORE THAN A MINUTE. I can see already that engine need to come out and have tins removed and cleaned. It also would appear to have a possible oil leak. Probably a seal. I would have front and rear seals and gaskets on hand to address this. Since you already know it needs the joints have them on hand also. Not sure what mounts are in it but most likely stock. Figure out what mounts you want to run and have those on hand as well. Pull the deck, check your belts and give it all a good cleaning and grease. My gut thinks ya got a good one.
Here is a Indak key that you can probably pick up at Lowe's, Home Depot or Tractor Supply, that ones from Ebay. As for the snow blower, I'm not an expert but how does it attach to the front? I've attached a IH snow blower, yours does not have the frame attachment as shown. By the way, great find. |
Welcome to OCC...........
![]() As for the key, ditto to what Marks1250 said.
Here you go, check your local Lowe's if Item # 95535 Model # OEM-725-0267A is in stock
If you get it to turn and actually start DO NOT RUN IT FOR MORE THAN A MINUTE. I can see already that engine need to come out and have tins removed and cleaned. It also would appear to have a possible oil leak. Probably a seal. I would have front and rear seals and gaskets on hand to address this. Since you already know it needs the joints have them on hand also. Not sure what mounts are in it but most likely stock. Figure out what mounts you want to run and have those on hand as well. Pull the deck, check your belts and give it all a good cleaning and grease. My gut thinks ya got a good I should grab all the parts ahead of time before digging too far into it.. I want to make sure I have everything I need.. Are there videos on replacing front and rear seals/gaskets. I assume there's some type of manual for doing this stuff? Thanks again for the advice! |
