Old 09-25-2019, 10:07 PM
Rwgarrison23's Avatar
Rwgarrison23 Rwgarrison23 is offline
Default Cub cadet 124 headlight routing.
I'm installing brand new harness on my 124 and i got everything nealy routed to where they suppose to go and I'm stuck with the headlight wiring. Where is the wire suppose to route to the switch? Do I have wrong switch installed by the previous owner? I tried to test the headlight to see if they are working. Is the tractor suppose to be running for the lights to come on?
Old 09-25-2019, 10:28 PM
MBY852's Avatar
MBY852 MBY852 is offline
You can find most anything in the Technical Library-Tractors section.https://www.onlycubcadets.net/forum/showthread.php?t=35
CC Model: 127 w/42" deck
CC/MTD Model: 2155 w/42" deck
.....DAD bought em new.....
Old 09-26-2019, 06:18 AM
cooperino's Avatar
Is your switch located on the left side of the dash tower? Shoot us a pic of your switch.
Old 09-26-2019, 06:49 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Lights should be able to come "on" even with key switched off. The wire to switch should be coming off the negative terminal of the amp meter.....based on wiring diagram. The meter will show a draw (discharge) when lights are on.
Plow blade
#2 Cart
QA36 snowthower
Old 09-26-2019, 07:26 AM
According to the Owner's Manual, the Light Switch is located on the LH of the Dash Tower. See attachment.
The Light Switch is independent of the Ignition Switch.
Old 09-26-2019, 08:16 AM
There's the light switch assembly terminal pointing down instead of out the circle hole if that how the original supposed to be.
Old 09-26-2019, 08:38 AM
Here are the images of the OEM & Replacement IH-62801-DC Light Switch.
Old 09-26-2019, 09:34 PM
I need the top one.
Old 09-27-2019, 07:04 AM
IH-62801-DC Light Switch is NLA from Cub Cadet. Your only options is look for a NOS one, or a good used one. If you are in need of one, try the Sponsors (Houtz, Patton, or Cub Classics) at the top of the page.
Old 09-29-2019, 07:52 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Or buy a toggle switch.....
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
