Old 09-22-2019, 10:21 PM
sawdustdad's Avatar
To address some of your questions on repairing your 1650, the tail light lenses are somewhat hard to come by, but you can sometimes find them on ebay. I did purchase a NOS pair from Lew (darkminion17) on this forum that he had put up on ebay. He might have some more. You could PM him or he might chime in here shortly.
The lenses are a bit easier to find than the entire fixture, but they often have cracks or chips in them. As for the bulb and socket, I'd go to NAPA or similar and find a fixture you can rob the socket from. They would also have the bulbs. Most of the new fixtures today are going to LED, so you might have to look around a bit.
The iso mounts definitely are a trouble spot, so get those addressed and I believe that the IH/CC replacement mounts are the best, but they are pricey. There are aftermarket mounts that cost less. I usually go to ccspecialties.org for parts. There is an article in the tech library on how to do the cradle mod. Might as well do that if you can while you have the engine out to do the iso mounts. look here: https://www.onlycubcadets.net/forum/...ead.php?t=4630
There are a lot of other articles in the tech library. Might want to change fluid and filter if it hasn't been recently. Open the tunnel cover (between the seat and the dash) and check the fan. It's plastic and often damaged. Clean any debris off the hydro and rear end. Look at the trunnion and see if it needs attention. fixing wear on the trunnion and replacing the springs does a lot to control speed up and down slopes. Look for the hydro lurch article in the tech library.
Put some new rubber on that puppy and she'll look like new.
Here's my 1650.
Old 09-23-2019, 03:42 PM
DustyD212 DustyD212 is offline
Thanks for the information. Your 1650 looks real nice. I found a set of new old stock bargman lenses for a good price on ebay, only issue is their amber. But thats not a huge deal. That bulb socket is the only other thing I still have to locate and the rear tail light issue will be addressed.
I'm going to purchase those Amber lenses now. Its the last set and its a good deal. I can always switch back to the red ones when I find them.
Since you own a 1650, can you do me a big favor and send me pictures of what the mounting hardware for the hood side panels looks like? I know the use one wing nut on each side, I located those. What do the other mounting bolts look like and whats their size? Also do you have the mower deck for yours. The original owner had the belt cover for the deck, what kind of mounting bolts does that cover use and size? It would be a huge help because I have the covers, but don't have the hardware to mount them. Thank's.
Old 09-23-2019, 04:05 PM
I just purchased the amber rear lenses, $20 bucks, it was darkminion17.
Old 09-23-2019, 09:54 PM
mortten mortten is offline
No othe boots on the side panels. There’s a spring that goes across from one side to the other. On the mower cover there are bolts captive on the deck. The cover holds on with nuts. 5/16 I beieve.
Doug
QA-36A
42" blade
Old 09-23-2019, 10:23 PM
Bob95065 Bob95065 is offline
Originally Posted by DustyD212 View Post
Hello,
I just getting a chance to post my first thread. I joined the forum about a week ago, after I received a free running and cutting IH Cub Cadet 1650 in Princeton New Jersey. Its my first IH Cub Cadet and I'm sold. The owner was moving to Maine, did not want to haul this with him and planned on buying a Kubota. At one time he also had a plow and trailer with it, aside from the mower deck and his family had two other cu s prior to the 1650, one being a 102. He listed it free on Craigslist and I was the first response.
I was just in a Princeton two weeks ago. I lived there for a while in the mid 90s. That would have made a nice carry-on back to California.
Congratulations on a great find.
Old 09-24-2019, 09:52 PM
IHCubCadet147's Avatar
Nice find, you can’t beat free!
Old 09-28-2019, 10:20 AM
sawdustdad's Avatar
mortten is correct. The only two things holding the side panels on are the wingnut and the spring across the muffler air box that holds the two panels together. The panels have edges that fit down inside the frame to hold the bottoms in place.
The mower belt cover drops over the captive bolts in the deck. Add nuts and lock washers. Bob's your uncle!
