Old 04-25-2019, 04:57 PM
austinewald austinewald is offline
Default Wide frame gear drive with hydraulics?
Hey I am looking for info on adding hydraulics to a gear drive. If I decide to do this, I would like mine to look clean. I found pictures and info about scott m's 1706 so this gives me a rough idea, but leaves out a few problems.
He didn't say where his pickup line was, so would you just tap the bottom of the trans and put a fitting there?
If anyone else has done this, I would like to see some pictures of it done.
Thanks, Austin
Old 05-22-2019, 07:01 PM
I believe I have seen the rear cover being used for pickup and return. You might try searching on google for pics, but I know I have seen it done.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 09-10-2019, 09:43 PM
I've came across this photo and many others. Only downside would be no creeper gear as the pump would interfere
Old 09-11-2019, 08:32 AM
Thanks, Austin
The rear cover could be used but I'd put the return line in the oil to keep foaming to a minimum.
But with as little GPM's we are talking about it might not be a problem,
and one is limited due to the small size of the reservoir.
Old 09-11-2019, 09:34 AM
I think the tranny has a drain plug at the bottom, could make the suction line there. And on his return line and pressure line, He tapped it at the shifter cover as shown here.
Old 09-11-2019, 02:12 PM
Merk Merk is offline
The size of the reservoir shouldn't matter on a closed hydraulic system. I would drill and tap the side of the transmission or reduction housing. Add a fitting for suction and return.
Project Uncle Dick
Cub Cadet 70
Old 09-11-2019, 03:23 PM
the size of the reservoir shouldn't matter on a closed hydraulic system.
I agree. My concern would be the pump, with focus on the Volume and Pressure.
Old 09-20-2019, 11:38 AM
Procure a side mounted pump such as used on the DanCo loaders.
Operated via a belt off the accessory drive pully on the rear of the engine.
DanCo added a pully to the rear of the OEM piece and used the right side tower as a reservoir.
Old 09-20-2019, 11:47 AM
cooperino's Avatar
Operated via a belt off the accessory drive pulley on the rear of the engine.
DanCo added a pulley to the rear of the OEM piece and used the right side tower as a reservoir.
I agree. I was going to suggest last week a GM Saginaw power steering pump with built in reservoir.
I'm not sure he has the pulley on engine but one could be added I'm sure.
Old 09-20-2019, 01:42 PM
That may prove to be rather bulky I would think.
Plus you would have to be careful where and how you mount it so as to not be in the way of the rams or frame uprights.
I sure like the compactness of the DanCo set up
