Old 09-05-2019, 05:20 PM
Giddy Giddy is offline
Default 782 IH series 1 or 2
How to tell or what to look for in a series 1 or 2 Kohler engine in a IH 782
Cub cadets models. 123, 1250, 3 -1450, 1650, 782,982 ,1711
Old 09-05-2019, 05:34 PM
An IH built 782 (S/N: <699,999) had a KT-17 Series I Engine in it from the Factory.
The Series II engine was not used until Chassis Serial 726125> which was built by CCC/MTD.
Old 09-05-2019, 05:38 PM
bill682 bill682 is offline
I had an early IH 682 with a series 1
It had a pipe plug instead of a cap for oil fill
It had a square air filter housing
However, the shortblock was replaced at sometime and all was placed on to the new series II. I didn't know until I noticed an oil filter provision on the side of the block.
Old 09-05-2019, 05:50 PM
What do you look for on the engine to tell .I have herd the series 2 have a oil filter
Old 09-05-2019, 06:21 PM
This pic shows where the provision for an oil filter and oil pressure gauge/sensor would be on a series II.
Old 09-05-2019, 07:30 PM
bill682:
WRONG. I have a Series II in my 784 and there is NO provision for an Oil Filter.
Old 09-05-2019, 09:21 PM
Some series 2's didn't have an oil filter, or even a provision for one as Roland said.
Now in da picture yall' will see a threaded plug with an arrow pointing to it.
(Don't worry the injins' are friendly in these parts)
Now pay attention, I'm only going to say this for the 100th ++ time.
If it is a threaded plug or a pressure switch or anything else threaded in there, it is it a series 2 or magnum.
If it is a series 1, the bossed area will have a small driven in cup plug in that place and the area will be smaller as there is no need for a robust boss as nothing is threaded into it.
Gospel.
The pipe plug for an oil fill, carburetors,air filters cooling tins, serial numbers etc are interchangeable between the engines so the presence or lack of those items don't mean shit.
A series 1 has no oil pressure spring/ball so it has about #5 on a good day
A series 2/magnum can run in excess of #80 cold.
I'll stop there as the internal differences are listed here many times by myself and others.
Old 09-06-2019, 06:40 AM
sorner's Avatar
sorner sorner is offline
My IH 782 has a series II in it. It does not have an oil filter provision. It also has series I tins. The only way I knew for sure is OlGeorge said to use an oil pressure tester where the oil sensing using goes. I have a thread a few months ago with the same question and what all I did to ID it.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
