Old 09-03-2019, 08:31 AM
CC2140 CC2140 is offline
Default Alternate bagger model cross reference?
I have a 1996 2140, that I am looking for a bagger for. My model according to the manual takes a model 190-305-100, which my only option really is finding a used one, which is proven to be a challenge. Buying the parts separately is not an option as it is way more expensive than I want to spend to bag grass.
Does anyone know if there is a comparable or cross reference model number that would be a good or exact fit? I can't find anything online.
Thanks,
Eric
Old 09-03-2019, 09:11 AM
cooperino's Avatar
I have 2 different tractors with "non matching" baggers. It didnt take much to adapt them to work. I did use Cub cadet made baggers which probably helped some.
Old 09-03-2019, 01:22 PM
I was kind of thinking of doing that as well, I can cut and weld metal and any two bin bagger should work as long as I can hang it and get a tight fit to the deck.
Old 09-03-2019, 02:30 PM
cooperino's Avatar
You can get a 3 bagger on that unit.. Ive found in my neck of the woods they are more abundant.
Not for nuthin, Years ago I had a crapsman tractor. I made a discharge piece for deck out of duct material that went from rectangular to round. The I used some corrugated 5" tubing to connect to a large yard trash can. I cut a center hole in the lid and made some vent holes. I was able to bag my clippings and leaves with it. It worked great! And it didnt cost much to make.
Old 09-03-2019, 05:20 PM
cheesedawg82's Avatar
cheesedawg82 cheesedawg82 is offline
This is making me think outside the box on another project I've got going on. I'm putting a twin on a Snapper, I don't think the factory bagger is going to fit, there's a whole bunch of places in my yard that the Snapper wont fit with the bagger on it, and I'm gonna need a wheelie bar if I let the kids cut grass. I can fix ALL of that with a couple pieces of ductwork, some conduit, and the neighbor's garbage can.
Thank you so much. That comment may have made my life SOOO much easier.
Grumpy old 149/1A tiller, Trusty Rusty 106, & a Massey Ferguson 10 to work the garden, Tiny Snapper to mow the lawn. Slowly accumulating attachments and quickly driving the neighbors crazy on a half acre homestead.
Old 09-04-2019, 09:00 AM
I wasn't sure I had enough vacuum for that, but good to know, there are more 3 bagger units for sale locally used than the standard double.
I envisioned which ever I get, I will have to modify somewhat with duct or plastic. Most likely some sheet metal screws and washers to keep it in place.
Old 09-04-2019, 10:01 AM
cooperino's Avatar
If you try the trash can idea.. You absolutely have to vent it. I made my large hole for the tube in the center. I then cut 1/2" holes all over the lid for ventilation.
Any High Vac deck should have sufficient flow to use a stock bagger or one homemade like i mentioned
Old 09-06-2019, 08:11 AM
Offered this guy $40.00 and he jumped on it, looks like an easy retrofit to me.
https://grandrapids.craigslist.org/f...942961146.html
Old 09-06-2019, 08:53 AM
I'm running a 19.5 HP opposed twin engine on a 28" hi vac deck with factory wings on the blades, I'm concerned that it might have sufficient flow to hover!
The garbage can mount will literally double as a functional wheelie bar for me, and I think I'm gonna have to add front weights.
Old 09-06-2019, 09:27 AM
cooperino's Avatar
Where the heck did ya get a 28" hi vac deck for that?
I get all three of my bags pretty full with damp grass and yes the front will get a little lite and I could make it do a wheelie when full but it is easily controlled.
