Old 08-14-2019, 05:13 PM
IHinIN IHinIN is offline
Originally Posted by SGragg View Post
Nice shed, Adam.
Why are your two overhead doors different widths?
I wanted a wider door to get my trailer thru without the risk of hitting the doorway. My trailer measures 103” outside the tires. A 10’ door would have been about 116”-118” between the seals. A little too close for comfort to me.
Old 08-14-2019, 05:53 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
Nice shed Adam!
IH cub cadets 800x3,1000,1100,1200x2,1250DS,1450,1650DS, 71,122x2,123, 73x2,106,107,126x3,127,147x2,86x3,128,149, 169x2 ,Original, cadet 55, to name a few
CCC machines
1282,1050,2072,1535,1440
Old 08-14-2019, 08:57 PM
Nice storage area, any heat going in it?
Up to 534 and counting...
Old 08-14-2019, 09:24 PM
Thanks guys.
No plans for heat or insulation but I did order insulated doors just in case. My other shop is fully insulated and heated. The new barn is for storage. The porch was the wife’s idea because we’ve been talking about adding a patio in the back yard. Our plan is to add a patio attached to the porch with a fire pit.
Old 09-08-2019, 03:05 PM
Concrete and doors are done. Now, I need to get a couple loads of dirt hauled in so I can fill in around the barn to actually get in the doors. There’s about a 2’ drop from the 12’ door to the ground.
File Type: jpg D60C86C4-CBB2-443D-ADE9-454FA9E7E01E.jpg (26.2 KB, 208 views)
File Type: jpg DB97A184-8493-40EC-B473-0E48B05503C9.jpg (21.2 KB, 208 views)
Old 09-08-2019, 06:03 PM
cooperino's Avatar
That looks great! Love the idea of one wider door and one smaller.
Old 09-08-2019, 06:57 PM
SGragg SGragg is offline
Inactive Member
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 09-08-2019, 08:51 PM
Nothing like the smell of fresh concrete in the morning!
I would go with with 3/4 stone and then Quarry Process.
Old 01-18-2020, 07:15 PM
So, last fall, I finished grading around the barn and sowed grass around it.
When I had it built, I planned to use an off-grid solar setup for lighting. Today, I started on the layout of the breaker box and charge controller. I’m using a Square D QO series box and breakers as they are actually rated for DC voltage up to 48 volts. The solar panels and charger are from Renogy. It’s their 200W premium package that includes cables, fuses, and a Bluetooth module for reading and adjusting the charger. I’ll be using a deep cycle marine battery for storage.
For light wiring, I’m using standard boxes, porcelain bulb bases, and 14-2 Romex wire. Inside will be 6 15W 12V LED bulbs. I found several options on Amazon that screw into standard bulb sockets. Outside will be a porch light by the man door and a flood light above the garage doors.
File Type: jpg 65411748-01FC-4FA6-91AF-41A8DAD7B612.jpg (30.6 KB, 172 views)
File Type: jpg C3877BE4-2416-465B-9EB8-33C039D61E6C.jpg (20.4 KB, 172 views)
Old 02-02-2020, 05:43 PM
sorner's Avatar
sorner sorner is offline
Looks great. I’m in the process of thinking about building something. Did you do it yourself or was it a kit?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
