Old 07-21-2019, 08:22 PM
sorner's Avatar
sorner sorner is offline
Default 782 crankcase breather tube problems
I took the 782 out for a ride today and it started smoking. I opened the hood and found the dipstick was popped out and some oil was coming out. The issue is related to the crankcase breather tube.
Here’s a little history behind it. I took the breather apart to replace it because it was the old umbrella style and I put a reed style in it. In the process the old tube was brittle and broke in pieces. It looks different than the ones on the bowl style air breathers, I have the flat style. This is a series II but with swapped tins and intake from the original series I engine. I looked for the replacement tube but only finding KH-52-326-06 listed which is the same part for magnums, and in pictures it looks like the magnum style. The one that came off looks different, there’s not as much of a bend in it and it’s not as long. I stuck one on that I have here that is from a series II with the dome style air filter and it pinches shut, which caused the dip stick to pop out.
So, which part number is it that I need to replace it? Or is there really no difference and I have some mutant part that came off?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 07-22-2019, 07:46 AM
For the KT-17 Series II Engine, the original Breather Tube was 52-096-18. It is now replaced by 52-096-55S.
Old 07-22-2019, 07:59 AM
sorner's Avatar
Both of those numbers are coming up as the cover plates, not the tube. I have a series II but it has all the series I parts swapped over, including the flat air filter with two wing nuts holding it down.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-22-2019, 10:04 AM
YUP, the ----55S is a breather assembly.
There is a difference between the Series I and Series II breather tubes. Different parts I see.
Old 07-22-2019, 10:20 AM
sorner's Avatar
I don't need the assembly, just looking for the tube. I found two styles listed under 52-326-06-S.
This one looks like my M18 and my other KT17 Series II with the dome air filter assembly.
This one is different but listed as the same part number. It does not look like the one I took off.
I took a chance and ordered the second one to try, it does not look like mine, but we'll see if it works. Maybe they changed the design of it at some point.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-22-2019, 10:37 AM
S52-326-06
KH-25-326-06-S (replaces KH-52-326-05)
google these and see iffin dey is what 'yall want
EDIT,
I see you beat me to it
the longer one looks like a vertical M-18 I have cut them slid in a metal thin wall tube to modify length/angle and they worked fine.
Old 07-22-2019, 10:47 AM
sorner's Avatar
Thanks George, that explains it. There is a rigid section in the middle of the one I took off, with a hose clamp, so it seems like a similar "fix". I'll see if the one I ordered will work, and if not, I'm cuttin' and splicin'.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-22-2019, 10:50 AM
ya and if ya have a tight fit, you don't need a clamp.
Oh my,
that could be all misconstrued.
I 'm just going away (giggling)
Old 07-22-2019, 11:07 AM
sorner's Avatar
10 characters.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-23-2019, 10:23 AM
The second one is what is on mine, no hose job necessary.
Up to 534 and counting...
