Old 06-24-2019, 11:23 AM
sorner's Avatar
sorner sorner is offline
I have been searching high and low on the internet for a picture of a KT17 with that style air filter, it looks like Gravely's might have had that but they were red, and the only other place I found one is on the cover of the Kohler service manual. Hopefully it is a replaced Series II, and they swapped over the tins from the series I. That'd be pretty awesome.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 06-24-2019, 01:05 PM
seems like I saw a Deere with a square air filter but not sure.
They also used those engines is many industrial applications, as well as
skid steer's
The oil sender area will tell you for sure what you have.
Old 06-24-2019, 02:42 PM
That is what my 782 has in it from the factory, Series 1. The filter is round.
Old 06-24-2019, 09:10 PM
sorner's Avatar
That’s an Allen screw.
And serial number tag on the side tin, same side as the ID label.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 06-24-2019, 09:35 PM
mortten mortten is offline
Engine is a 1979. Is there a spec number on it? Spec number 24300 and higher is a Series II.
Doug
QA-36A
42" blade
Old 06-24-2019, 11:13 PM
sorner's Avatar
24136a. But it might have been swapped tins.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 06-25-2019, 12:15 AM
SS5150's Avatar
SS5150 SS5150 is offline
That's an early series 1 air filter housing. My Grandparents 782 had that housing.
I don't have the serial # of their tractor offhand but I'm thinking it was early production, definitely IH built.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 06-25-2019, 12:31 AM
sorner's Avatar
So as I’m trying to figure out what I have, why does this engine have an Allen screw instead of a plug for the oil pressure switch. Ol’george and several other places say that’s a tell tale sign it’s a series 2. If the engine runs it runs until it won’t no more. But I would like to know what I have. I guess I could go mow a hill and if it makes a window it was a series 1?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 06-25-2019, 09:01 AM
Throw that hill roomer out the window the rod went through.
Me thinks you have a series TWO
Now if you want to sleep better, just screw a pressure gauge in that hole where the allen plug is, and start it up.
Use Any gauge or fitting you might have around will work.
about 5 pounds you have a series 1
Series 2 runs #50+++ (I've seen #80 cold) down to #15 hot.
Old 06-25-2019, 09:04 AM
sorner's Avatar
I like to sleep well. Thanks for the tips George. I got a heckuva deal if that is a series 2. Ill pick up a pressure gauge and report back.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
