Old 04-24-2019, 08:30 PM
Pulled snow duty 125 out of shed.
pulled grass duty 125 out of shed ( started right up--star tron gas treatment and a battery tender work great )
Put snow duty 125 back in shed.
mowed for the first time this year
Put the 125 back in the shed
Old 04-25-2019, 08:59 AM
Ordered some parts from Jeff, got cork gaskets in the mail so reinstalled the hydro, replaced the engine side coupler, (good thing, the aluminum cup that it bolts to was shot as well) took steering column apart and cleaned all of the old grunge out/ regreased it with fresh. Hydro linkage seems to be a little loose, don't see any adjustments possible to tighten it up, will have to see once I get everything hooked back up, will fire it up on a jack to see, before I put the body back on.... hopefully if it walks down towards neutral, the linkage on the parts 129 is in better shape.... I will need to get new tie rod ends for the link from the shift rod to the shift linkage on the trans anyways.
Old 04-28-2019, 03:01 AM
Farmstock Farmstock is offline
Installed tubes in the rear tires of my 125. What a job.
Old 04-28-2019, 06:26 PM
CadetTommy's Avatar
CadetTommy CadetTommy is offline
Made the brakes work on the 126, pulled the 42" deck and cleaned it all out. Hoping to find a NF front blade for it. Seems there's 5 WF blades for every NF one. Also got the blades for my 50C razor sharp, but there's bad news on that deck.
'74 IHCC 108 - 38A, supersteer axle
'75 IHCC 1000 - 44A, Sears wheel weights
'87 CC 1872 and 1811 - Haban, 44C
'96 CC 1863 - 54GT
'79 JD 400 - 60" deck
"Projects" '67 123, '65 102, '71 126
Old 05-10-2019, 12:12 PM
Kjamesm's Avatar
Kjamesm Kjamesm is offline
My neighbor I sold my restored 102 to put some duals on the rear of it! Kinda jealous.
Old 05-20-2019, 09:17 PM
IHCubCadet147's Avatar
IHCubCadet147 IHCubCadet147 is online now
I finished putting the motor back in my 129 after changing the oil pan, then put the mower deck on and took it for a short ride.
File Type: jpg 15908BBE-EEFC-4C38-9A31-71A070F1B500.jpg (27.8 KB, 105 views)
Old 05-24-2019, 09:46 PM
Nice 129!
Old 05-25-2019, 09:07 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Mowed with the 782, and took 7 trailer loads of hedge/tree trimmings out into the woods to dump with the 122 mutt. Trimming and hauling took 3.5 hours .
Just noticed that the muffler was blowing out (hard to get 60 yrs out of a muffler these days) so I ordered a replacement.
Did I mention it was in the lower 90's today?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 05-25-2019, 10:04 PM
willys55's Avatar
willys55 willys55 is offline
Mowed the lawn with the 100 and then parked it next to his older big brother
64 Cub Cadet 100
Also have quite a few Non Cub Cadets in the Shed
Old 05-26-2019, 08:19 AM
Attachment 99983
Good looking tractors! I really like the red and white on the 100.
