Old 11-18-2010, 07:54 AM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default Great
Thanks George. Good advise there. The block cleaned up well. I guess I should dump the oil and replace before I start the motor?
Old 11-18-2010, 09:30 AM
JOHN SCHUTTE's Avatar
JOHN SCHUTTE JOHN SCHUTTE is offline
Jay, one tip I have used and had good success is to use Permatex Copper Coat spray on the head gasket prior to installation. It helps seal off any imperfections that may cause a leak in the future. Two thin coats is all you need. On the down side, it is kinda pricey, but it works.
Old 11-18-2010, 10:36 AM
I also have used the spray copper coat a couple of times with a questionable surface & had no problems, I just can't say if it would of worked or not worked without using it.
Old 11-18-2010, 11:36 AM
ljones's Avatar
ljones ljones is offline
Here is the correct torque pattern and intructions for cheacking the heads flatness.
Old 11-18-2010, 08:00 PM
kenny9815 kenny9815 is offline
Default head gasket change
Make sure when you start reassembling the head bolts that you put a small squit of vegtable oil on the threads. Then torque in sequence. Seems to hold torque a lot better.
Old 11-18-2010, 09:36 PM
Default cleaned up and on
Ok, grabbed a piece of glass off a table at home, Shhhhhhhh! dont tell the wife, and got the recomended sand paper as per MattG, thanks Matt!!!!!
Yay, finally after a few sheets and some sore arms, it was all nice and even. It had some high spots and where it started leaking it was off in that area.
So I cleaned the threads up and put the new gasket on, mounted Mr. Straight Head. I bought new Grade 8 bolts and new grade 8 nuts for the studs.....I was just too lazy to wire wheel everything he he. Here she is.
Well here is the funny !!!! As I go get my torque wernch out, I dont have a 9/16 deep socket to fit it ha ha doh !!!!!
Old 11-18-2010, 09:50 PM
Sminkey
Guest
Posts: n/a
Default Nice work!
That's funny, yesterday I ran into the same issue, needed a deep 3/4" socket so I had to run out and buy one:biggrin2.gif:
Old 11-18-2010, 09:56 PM
Default lol
glad i am not the only one !!!! ha ha
Old 11-19-2010, 10:20 AM
Mizar N68X Mizar N68X is offline
That is why I do not call myself a "MECHANIC".
They own tools for every job!!!
Looks like a nice job on the resurface there JaysNJcub127!!!!!
Old 11-19-2010, 10:27 PM
william1041200's Avatar
it happened to me too. the 9/16 deep socket... keep accumulating things in addition to the cubs!
