Old 04-13-2019, 08:59 PM
IHCubCadet147's Avatar
A friend of my dad’s just converted all of the lights in his shop to LED. Before, you could barely see in there, now you almost need sunglasses.
Old 04-14-2019, 08:52 AM
Thanks folks!
Really appreciate the suggestions.
Got the last of the walls covered w/new white steel yesterday.
Now it's time to drop all the old lights and get the new steel ordered for the ceiling.
Thinking now of 2 strings length wise each about 4' in from the walls.
If I get thee 4' fixtures, how far apart should they be chained together?
Maybe 4 lights each side w/2' between fixtures?
Old 04-21-2019, 10:55 PM
steelsmith steelsmith is offline
How do the LED 's work in unheated space, would like to up grade the lighting in my garage but it dose get cold out there.
Thanks
Joe
Old 04-22-2019, 06:02 AM
Finsruskw, can you elaborate on the steel you are putting on the walls? Where are you getting it and what is the cost. I'm thinking that that will look very nice. Can you post some pics of it up?
Old 04-28-2019, 05:05 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Thanks s
Joe
The Feit I have from Costco works fine in the cold. I don't think you'll have cold issues with any LED fixtures. Except MAYBE LED replacement bulbs for existing florescent fixtures using the ballast????
Plow blade
#2 Cart
QA36 snowthower
Old 04-28-2019, 05:20 PM
Billy-O's Avatar
Thanks s
Joe
Plow blade
#2 Cart
QA36 snowthower
Old 04-28-2019, 06:10 PM
Got started on the ceiling after getting the walls done and the big door trimmed out last weekend.
The bill for the steel on the ceiling (538.34 Sq.) came to $422 or about $78.39/Sq. Price included a bag of screws.
So far so good. Although I didn't realize that I have 2 colors of white till the ceiling went up!! It's "bright white" and the walls are "bone white"
Old 04-29-2019, 08:20 PM
Looks good, is that 538 squares or square feet?
.78 cents a sq ft
Up to 534 and counting...
Old 04-30-2019, 08:06 AM
Square feet.
Sorry bout that, forgot the '
Paid a visit to the local Menards yesterday to look at lights.
Seems all the newer LED fixtures have non replaceable bulbs. If one bulb goes south it's new fixture time!
I could use my old crappy fixtures and add ballast bypass bulbs for about $15 ea, but I can get a new 2 bulb 4' LED fixture 2 bulb unit for $35. 8 footers with 4-4' bulb units were $80, again, no replacement bulbs. Save $15 and buy 2-4' units instead of an 8' and space the apart some.
And I really don't want to hang the old ones back up on a new ceiling though.
and ma wind up springing for 8 of the 4 footers and space them 4 down each side about 4' in from the wall
I did pick up 2 of the $35 units just to see how they would work where I plan on putting the mill.
These are hard wire units, I can install short runs of conduit between fixtures. The cheaper ones have wires and plug ins to link them together. But then you have all the extra wire to deal with as they have special 3 prong receptacles on one end and a length of wire on the other end.
Old 05-07-2019, 07:20 PM
Steel work is all done
Got started on the lighting today as well
4' LED's spaced 2' apart.
The mill I bought last month will live in the corner.
