Old 04-12-2019, 07:07 AM
Leadslingingdaddy's Avatar
The collar flange needs to go over the blade if it isn't already.... So the U design needs to point towards the deck not the ground...
Old 04-12-2019, 07:26 AM
rmilcic's Avatar
rmilcic rmilcic is offline
Here is a closer Pic. Let me know if that looks correct?
Old 04-12-2019, 07:43 AM
Yea that looks right in the other pic it looked as if you had the square stock under the blade...
Old 04-12-2019, 07:44 AM
Ummmm is it me or are the blades on upside down?? Right side discharge correct?
Old 04-12-2019, 08:30 AM
rmilcic's Avatar
It is right side discharge. Those are high lift blades. Closer pic attached for confirmation.
Old 04-12-2019, 09:24 AM
Wow... had to go back and stare at that pic.... !!! You are GTG at this station... go see your drill sgt and move to the next station.
Old 04-12-2019, 09:31 AM
rmilcic's Avatar
Thank you, appreciate you taking the time to look.
Old 04-13-2019, 09:36 PM
rmilcic's Avatar
Tractor is running great. Its rolling coal up the steep hills while cutting grass.
Old 04-15-2019, 07:37 AM
rmilcic's Avatar
1 more question regarding the 60 inch Haban. The rear mower wheels. Looks like the left side is inverted in. Should these wheels be further away or closer to the rear tractor tires? See pic.
Old 07-09-2026, 03:35 PM
neilespo neilespo is offline
Default Haban 60" deck tag # 374190
https://www.dropbox.com/scl/fi/6xxoj...=iuy5rnvc&dl=0What blades for a Haban 60" deck.. tag # is 374190.
Thanks in advance.
