Old 04-08-2019, 08:09 AM
rmilcic's Avatar
rmilcic rmilcic is offline
Default Haban 60 Inch mower deck blades
Hi everyone,
I'm new to the form. I just picked up an 1782 Cub. I pulled the deck last night and was wondering 1. If anyone new the model of this deck and 2. Where I can get another set of what looks to be high lift blades? Pics attached
Old 04-08-2019, 10:04 AM
190-325-100 deck
759-3839 blade
759-3840 hard coated blade
https://www.cubcadet.com/equipment/A...6-52e762f896d5
Old 04-08-2019, 10:39 AM
rmilcic's Avatar
190-325-100 deck
759-3839 blade
Thank you for the quick reply! Is it really worth 93 more dollars for the hard coated blades? Just curious. Thank you
Old 04-08-2019, 12:18 PM
I don't think so unless you are mowing sand.
Old 04-08-2019, 01:28 PM
rmilcic's Avatar
Old 04-09-2019, 06:52 AM
rmilcic's Avatar
Hi Sam I got 1 more for ya. Looking to replace the bolts for the spindals as they are rounded.. No one seems to have them..Any ideas?
>Part number: HA-GM181702 Screw, Hex Cap, 1/2-20 X 1.75 Lg GR5
Old 04-09-2019, 07:26 AM
Mcamp Mcamp is offline
Just buy at your local hardware store.
Old 04-09-2019, 08:04 AM
By "rounded" I am assuming you are referring to the hex head part??
if that is correct, then a grade 5 bolt of 1/2-20 TPI. by 1-3/4 long will work fine.
Tractor supply, hardware, John Deere, Case IH dealers will all have them.
Old 04-09-2019, 08:24 AM
rmilcic's Avatar
Yes sir, rounded as in the hex part is worn out. I need to replace the bolts. really appreciate the help!
Old 04-09-2019, 08:28 AM
rmilcic's Avatar
These are also 2 inches long (See pic) Still think the 1-3/4 will work?
