#61
Nice job, looks clean. I used the kit on a 126, with tri ribs feels like power steering
-Rick IH 782 IH 126 CCC 1863 |
#62
That what I've heard Rick. I am putting on some narrow tri-ribs too. I am looking forward to feeling the difference. It does make sense that it would turn easier with that bearing on there.
Wayne
#63
For other newbies - good to know that other brand rear wheel weights may fit just fine. Our Sears is going out of business so I got two 55# wheel weights for about $50 plus tax - and they fit like they were made for it.
On the 149 steering wheel, I am guessing the center emblem was just a foil with a sticky back. Is that correct? I cut a piece of steel to fit in mine that I can attach with double sided tape and the new sticker would have a place to adhere to. What is everyone else doing about the steering wheel center emblem?
Wayne
#64
Thanks, I am the right track then. I cut mine from 14ga steel, hopefully it will stay put.
Wayne
#66
I was planning on doing the same for my 149 steering wheel as well.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
#67
Temperatures were up today so I decided to do some painting. I have to paint outside. Everything was going really well; working on the third coat of white and "whoosh" a gust of wind comes through and suddenly I have a bunch of crap stuck to my wet paint! Sometimes a fella's patience gets seriously tested!
Wayne
#68
I am missing the springs and spacers for my rear brakes. Does anyone know of a source or something else that can be used. I'm not even exactly sure what the spacer looks like or does? Thanks in advance for any advice.
I gave up and just bought a spring from Ace and shoved it in, hopefully it will work ok LESSON LEARNED - I have the brakes that don't require a spacer or spring. Thanks to Dart1917 and cooperino for educating me! That is a great relief.
Wayne
#69
I decided I wanted my air cleaner to be a little different, so I painted it black and made a sticker for it. Just wanted to make sure there was no confusion on who made it.
Wayne
#70
With the PTO removed should the basket pulley be able to shift 1/8 turn? It stops where the holes lines up with the set screw holes, but can move 1/8 turn clockwise. It feels like it locks at both ends of travel, but it shifts with some pressure. The front bearing has not been removed. Thanks.
Wayne
