A little 1/4 drive socket wrench and some patience. If it is bad, just bend it back and forth unit the other mount snaps off.
OK. Wil ltry some more patience with the socket before I bend it off. A question just occured to me, how to test the solonoid’s condition. Are they go/no go, or do they conduct less primary current with age, and use ? Thanks, Steve
WHY are you trying to remove the starter solenoid? Solenoid can " not work" or you can have poor starting issues such as slow to turn over. Whatever you problem may be, use a multimeter to diagnose. You can test without removing the solenoid before you remove it all for nothing.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
A Solenoid is a Magnetic Switch. With no voltage to the small terminals (coil), the switch is open. With 12VDC to the small terminals, the coil is energized pulling up the contacts, allowing Starter Voltage to pass through contacts being closed.
Full disclosure: 105 has been increasingly difficult to start in below 20deg temps. Yesterday( 6 degrees) it turned over slowly and would not start. Drained the battery twice while the motor seduced me with a series of “almost” starts. Gone through the ignition system cleaning wiring connections. The solonoid connections are too difficult to clean in place, so I thought i’d take it out to clean them. I have a new replacement on hand, and if the old one doesn’t check out I can replace it. The old solenoid is the 105’s original. Thanks, Steve
You could do a voltage test on the big terminal going to the S/G during cranking to verify the full battery voltage is going through the solenoid. I have doubts the solenoid is to blame though, never had one cause what is happening.
What size is your battery? I have a 400 ca battery in my 680 and once it’s gets below 25 degrees; it’s still not enough. My 104 was hard to start today and that was with its battery, a car battery and 50 amps from the battery charger. Also, what weight oil are you running?
Kris 63 CC Original w/ 38” deck and front plow 72 129 50” deck, 42” blade 73 86 42” deck, 42” blade 84 CC 680 w/50” deck and 42" plow 89 CC 1811 46GT" deck,QA42A, 38" IH 1A tiller, Brinley-Hardy plow x2 1982 Gilson Lawn Tractor with 38" deck ![]() |
I generally have a 270/300 CCA battery in my tractors and they start in cold weather without any assist, sometimes sitting a month or more. If your starter/gen is in good working order, ignition system, plug, wire & connections, timing set properly, carb & fuel system free of any demons, it should fire and run pretty quickly. Usually the solenoid is not the issue with slow cranking. just my opinion ! good luck
![]() PS if any of those systems are in marginal condition, they will rear their ugly head when the weather is the worst ! |
