Old 01-10-2019, 07:41 PM
Dstein16's Avatar
Dstein16 Dstein16 is offline
Default Bad day :(
Good ole' northern PA got some snow today so I went to plow with my SGT. Started it right up like any other day and let it warm up for 10 minutes or so before I got on. Went to move forward and it didn't move. Sure enough, a second later, driveshaft goes BOOM. What happened!? There were no leaks under the tractor, it started just fine, and it has been running well all season.
I only snagged a few pics. I won't have time to tear into it until tomorrow night. I'm guessing this is going to be a pain and $$$...
-Derek
Cub Models: Original, 100 (x3), 1282, 1572, XT1 LT46
Old 01-10-2019, 07:48 PM
That is not a 1782, the 1782 has a CV drive shaft.
Old 01-10-2019, 08:21 PM
Dstein16's Avatar
I apologize, you are correct. Quite honestly, I do not know what this tractor is. It has a cyclops fuel tank and fender pan, and sheet metal hood/sides and dash from something of an 82 series. It also has a Kubota D950 diesel engine. A homemade tractor that I picked up very cheap and it worked many hours for me.
Here is another pic I forgot to add to the first post.
-Derek
Old 01-10-2019, 09:07 PM
athomas's Avatar
athomas athomas is offline
Likely serious if input shaft to trans doesn't turn !
Old 01-10-2019, 09:25 PM
Ya done blowed it up, now ya gotta send Jeff in P.A. a parts order, sows he can turn ya up sum new parts.
Old 01-10-2019, 10:27 PM
Make sure the input shaft still turns, if so, I have a replacement splined rear coupler ready to go.
Old 01-10-2019, 11:16 PM
Dstein16's Avatar
The input shaft is the splined one in the picture (where the rear coupler assembly would mate to)? Should that shaft be able to turn freely by hand?
-Derek
Old 01-10-2019, 11:22 PM
With the rear jacked up, yes, it should turn. Just want to verify it's not jammed before you spend funds on parts.
edit--
Hydro shaft should turn whether the tires are on the ground or up in the air.
A gear drive should only turn with tire(s) in the air.
Old 01-10-2019, 11:28 PM
Dstein16's Avatar
Thanks Jeff. I’ll check it out tomorrow after work. Fingers crossed!
-Derek
Old 01-10-2019, 11:34 PM
I sent an email to you a little earlier. That's the best way to contact me.
