Old 11-18-2018, 11:11 PM
nophun nophun is offline
Default 1863 followed me home
Good runner, mows very nice until..
So I'm making a lap around the place, giving it a shakedown and I hear this awful sound. The closest thing I can think of would be a dried rusty ball bearing spinning; not a grind but more like a screech or a howl. The sound lasted about a full second. I turn the deck off and head to the shop thinking it's an idler but then it makes the sound again, but only for a split second.
The sound sounds like it's coming from the driveshaft/hydro area. I'll dig in there tomorrow to see if there's something tangled up there.
Other than that, she runs really nice, plastics have some scratches but no cracks or breaks. Headlights even work! Hour meter is showing about 330 hours, some things make me feel it's accurate, some not so much.
Old 11-18-2018, 11:46 PM
Vrobert's Avatar
Vrobert Vrobert is offline
My 1811 with hydro screeches when I start the engine and screeches when the engine stops. I suspect the sound is from the hydro but I did replace the fluid and filter. Maybe my issue is similar to yours. I'm interested in what you learn.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 11-19-2018, 03:50 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
I had a loud noise on my 1863 drive line once. It was the arm that depresses brake safety switch rubbing on the drive shaft. Does it go away when you mash the brake?
Cannon
Old 11-19-2018, 06:36 AM
bugeye bugeye is offline
While you have the driveshaft cover removed for a look, might as well remove the driveshaft. Disassemble, clean, inspect and grease the CV joints. A few squirts in the zerks probably won't help much if never serviced.
The PTO bearing will screech. Use an impact air wrench to remove the bolt at the crankshaft. A fine pick will remove the seal to allow the bearing to be greased. Use a high temp grease.
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 11-19-2018, 07:40 AM
I used a needle adapter for a grease gun to grease sealed PTO and idler bearings.
https://www.youtube.com/watch?v=fl7cZBzjFVQ
Old 11-19-2018, 09:50 AM
I use a syringe/needle, to inject grease under the lip of the seal.
Old 11-19-2018, 05:57 PM
Can someone lead me to how to get the release knob off to take the drives shaft cover off? I pulled and twisted and it just laughed at me.
Loose bolts everywhere on this thing, all four of the rear-end mounting bolts were loose, luckily no stripped threads. Found a bent brake rod too, possibly because of the loose bolt.
Old 11-19-2018, 06:33 PM
Adjustable wrench on the flat part of the rod and pliers on the knob. Check the front tranny mounts also.
Old 11-19-2018, 09:02 PM
Thank you Sam, that worked perfectly.
And I found the source of the noise: It's the lever for the safety switch rubbing on the driveshaft.
I also found a minor leak at the relief valve block, so I'm going to pull the fender and fix, adjust, clean, and tighten everything under there and should be gtg.
Old 11-20-2018, 08:10 AM
While you have the fender off, pull the fuel tank clean it out and all of the crud on top of the tranny. Pull the fuel shut off valves, clean them out or replace them, new fuel tank bushings and new fuel hose. You'll be glad you did.
