Old 10-13-2018, 03:52 AM
Awilson Awilson is offline
Default 149 Headlights
What lights from Harbor Freight did you put on your 149? I'm painting mine and want something cheaper than O.E.M.
Thanks
149,1250, #2 Cart, Brinley Spring tooth plow, #2 Tiller, 42" Front Blade
Old 10-13-2018, 06:42 AM
The OEM headlights that IH/CC used was the #4411. It can be had at any Auto Parts Store and numerous places on line.
Old 10-13-2018, 07:28 AM
john hall's Avatar
See if Larsen lights can switch over the sealed beam number Roland posted (I think that's a pretty standard item) to LED, you won't regret it if you plan on working at night.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 10-13-2018, 07:29 AM
hyperlightboards48 hyperlightboards48 is offline
I think the original thread that was dug up was referring to tail lights. If so I think these have been used.
https://m.harborfreight.com/automoti...air-93227.html
Tanner
Old 10-13-2018, 08:43 AM
sir_lancealot sir_lancealot is offline
Any 12 VDC PAR36 bulb will work. You can get them most anywhere. Home improvement stores have them in their landscape lighting section.
Old 10-13-2018, 09:08 AM
IF, you are looking for the Rear Lights, then you will need: IH-545616-R1. They are NLA from Cub Cadet, so online searching will be needed..
IF, you are going for aftermarket, just about any "marker light" will work.
