Old 08-15-2018, 12:28 PM
Nice 129, you have there.
Old 08-15-2018, 01:34 PM
IHCubCadet147's Avatar
Thanks, it still needs work, but it looks good.
Old 08-15-2018, 04:15 PM
TNTs CC TNTs CC is offline
Scored some engine side covers for the 1650 I just bought.
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
Old 08-15-2018, 09:59 PM
Mr Bob's Avatar
Mr Bob Mr Bob is offline
Default New TO ME 149
Today I started to check for things that needed to be done on the 149.
Tightened up the steering cam adjusting screw and put grease in the steering box. Then greased the axle spindles. Helped the steering a lot. Took some play out and steers easier. Then I took off the inspection plate between the floor boards. What a shock. Piled full of fine dirt. No oil, just dirt. Hosed it off with water hose and came pretty clean. Then hosed off bottom side of engine on carburetor side. Got water in the points and like to never got it out so it would start. Put it back in shed and called it quits for the day. Pictures attached. First two pictures are before and last two pictures after water hosing. Not that you would have trouble telling that. Have a great day.
Bob
Old 08-16-2018, 09:46 AM
jbrewer's Avatar
jbrewer jbrewer is offline
You probably lowered the operating temp of that pump by about 40 degrees by removing the insulating coating of dust . Good work!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 08-16-2018, 09:14 PM
Gompers Gompers is offline
Cleaned up a couple of hubcaps I picked up earlier this year.
Not perfect, but they will look pretty damn good on a tractor!
Got them with a blown up 782 with a 48gt deck for $150 in April I think.
File Type: jpg 5734A2C1-0D89-471C-BD62-85BF334DA6BE.jpg (28.5 KB, 164 views)
File Type: jpg ADDB6E90-E3AE-49A5-9779-FFFA6B170133.jpg (20.9 KB, 162 views)
Old 08-16-2018, 09:17 PM
jbrewer's Avatar
Man, that is some great work! Good elbow grease on those bad boys!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 08-18-2018, 09:28 PM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Picked up parts for the ol 1250. Side panels, muffler box, muffler, and the baffle. 60$. I think it wasnt a bad price, eh?
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 08-19-2018, 07:02 PM
Cut the grass with my new mower as the 3235 made someone else a nice mower.
Old 08-19-2018, 08:14 PM
Nice job LP I’m a fan of course. I’ve never mowed with a cast end before. I’ve got one just haven’t ever mounted it. Looks sweet
