Old 08-07-2018, 01:33 PM
cooperino's Avatar
Let me ask another question. You said the bogey wheels are worn. In the number 6 position do any of them touch the ground? if the deck is teetering side to side while your mowing I can't imagine that you would get very good results.
Old 08-07-2018, 01:56 PM
Old 08-07-2018, 03:06 PM
Chad126's Avatar
Chad126 Chad126 is offline
In addition to that already stated:
Are you cutting wet or dry? Dry cuts will cut and discharge better.
Tires filled evenly?
Is this a 3 blade or two blade deck?
Again, as stated above, are you running wide open? You need to be if you are not. J-Mech mentioned this and I don't see that you ever confirmed that or not.
Any chance you can take a pic of the grass line left behind?
"Equality is about giving everyone an equal chance, not about giving everyone an equal result."
1971 126 w/ Brinly Sleeve Hitch, Plow, Discs, and Cultivator
http://www.onlycubcadets.net/forum/s...ad.php?t=50159
Old 08-14-2018, 07:47 AM
CC2140 CC2140 is offline
Default Update
I have ripped the deck off, did the annual cleaning, lube of spindles, sharpening of blades, cleaning the inside of the deck, replaced the deck wheels.
I dropped it to level 5, still mowing at WOT and in 3rd gear. Cutting seems to have drastically improved.
Thanks for the tips.
